Help Required No Clue about adding a satelite on SeaTel 2200
lpe427
DAC2200
PersianGulf
Hello,
I am working on an offshore barge in the middle east where we have a Sea Tel DAC 2200 Unit.
the technician who installed it very long time ago he did the setting for us to have Arabsat.
We would like now to change to another satellite, as it would be easy to get the signal there, we wished if we could get ES'HAILSAT 25.5E as we have Bein Sports receivers and we would want to watch these channels:
BeIn on Eutelsat 25B/Es'hail 1 at 25.5°E - LyngSat
But facing the sea tel dac 2200 unit I have no idea how to put the data, I mean I know how to put the numbers and all but what should I put in all of these??
THRS ?
FREQ?
[URL='http://www.marinesatellitesystems.com/index.php?page_id=1037#896']Baud ?
[/URL]
[URL='http://www.marinesatellitesystems.com/index.php?page_id=1037#895'][URL='http://www.marinesatellitesystems.com/index.php?page_id=1037#897']Tone ON/OFF? [/URL]
[URL='http://www.marinesatellitesystems.com/index.php?page_id=1037#895'][URL='http://www.marinesatellitesystems.com/index.php?page_id=1037#901']NID?[/URL]
[URL='http://www.marinesatellitesystems.com/index.php?page_id=1037#895'][URL='http://www.marinesatellitesystems.com/index.php?page_id=1037#901'][/URL]
[URL='http://www.marinesatellitesystems.com/index.php?page_id=1037#895'][URL='http://www.marinesatellitesystems.com/index.php?page_id=1037#901']Your Help would be so so so so much appreciated! [/URL][/URL][/URL][/URL][/URL]
pgh13
Midlands UK
Is this any help?
h__p://marinesatellitesystems.com/index.php?page_id=810
Can you bring up a list of the existing numbers entered ?
lpe427
DAC2200
PersianGulf
Is this any help?
I know how to go to the setup and change values but I don't know what numbers should I put in there.
How do I calculate FREQ or what is the NID number ?
I would like to put the data of these channels as I am pretty sure I could receive them.
lpe427
DAC2200
PersianGulf
And I am using a universal LNB by the way as it's related to calculate the FREQ but I don't know how.
Universal LNB, two bands, operated by TONE
Tone on - subtract 10600 from frequency required and enter into freq
Tone Off- subtract 9750 from frequency
BAUD should be symbol rate
I would also have expected something like POL for polarity, and options of H or V
lpe427
DAC2200
PersianGulf
There's volt that has the vertical option.
I did the calculation and tried with tone on and off but no luck yet
lpe427
DAC2200
PersianGulf
It's frustrating because I got few channels from 25.5 E but not Bein Sports package
should they have different settings because they are running on
2/3
DVB-S2
8PSK
I don't have any idea?
What channels are you getting on the new receivers ?
lpe427
DAC2200
PersianGulf
I just checked and it turned out they are not actually in eshailsat 25.5 E
but from Badersat 26.0 E
but weirdly they showed as eshail channels when I put the new values and did a search in eshailsat
the channels I got are oman tv package. . this is one of them
Oman TV Sport - LyngSat
So, you are close, but not exactly on the satellite you require.
Change the SAT listing to 0255 E if possible and rescan.
lpe427
DAC2200
PersianGulf
I did that, also tried to twist it like 25.6
or 25.4 and like that.
but no luck.
lpe427
DAC2200
PersianGulf
the frequency of the channel I am looking for is 11547 so tone off ;
11547 - 9750 = 1797
that's the freq I put.
along with baud and polarity
I don't know if I am missing something.
lpe427
DAC2200
PersianGulf
Should I try putting the nid?
but what is it for my case?
Any help?
Archive4
At the bottom of the page on the previous mentioned link is a download pdf for the installation and operation manual. It´s quite a long read but should have all the info you need to adjust the dish. Is it possible the dish isn´t moving when you try to input the new satellite details? Might be worth getting someone to watch it and try sending it well west, say 0.8 W , if this is possible.
The link again, in case you missed it
Operating SeaTel Antennas, The DAC 2200 Controller, Targeting the satellite, Turning off the Error light, SeaTel DAC 2200 Installation and Operation Manual, , , ,
RTFM ;)
Mickha
North West
Just searched, and RTFM is Read the * manual, something I seldom do, unless I get stuck;)
I assume that's code for some kind of rule violation. Please PM me so I know, and I will ensure it won't happen again.
I don't think it's directed at you but encouragement to lpe427 to follow your link as a first course of action.
