Longitude and latitude
Robo44
!.1 mtr
Ireland
Hi i can't get my head around what to put in my reciever
My long and lat are
52.274611 Lat
-0.558077 Long
Ive a Spiderbox 9000HD so what exactly do i enter when setting up ?
satelliteman
52.2 N and 0.55 W.
Robo44
!.1 mtr
Ireland
On my stb i put in 52.2 N for latitude
But for Longitude i have to put in 000.0 ?
So how do i put in 0.55 west ?
hairybadger
Bricoleur
46.1N 6.4E
see sig
-0.55
0.55W
359.45
something like that :)
Robo44
!.1 mtr
Ireland
Robo44
!.1 mtr
Ireland
Oh i see what you mean ill try putting that in as I've just put 1.0W for the time being
Robo44
!.1 mtr
Ireland
No it won't let me put that in either :( If i just put in 1.0W will it make a lot of difference ?
Trust
Nijmegen Netherlands
Why not 0.5 or 0.6 ?
Robo44
!.1 mtr
Ireland
I'll give it a go later.
sonnetpete
wordpress.com
Normandy, France
Found this, it may help :
Spiderbox 9000HD Beginners Set-up Guide
Press the menu button.
Select the Installation section by scrolling right/left
Go to motor setup, press OK
Enter pin code "0000"
Press the green button to allow you to enter your longitude and latitude.
Longitude is switched between E & W by pressing the < and > buttons.
Enter your longitude by using the number keys. Note: if your Longitude is 1.5W (for example) you must enter 001.5W in this field.
Enter your latitude, e,g, 55.6N. You can change N to S with the arrow keys too, but most of you won't want to do that.
Scroll down to save and press OK.
(Therefore, in your case, I'd try entering 000.5W)
