- Oct 21, 2006
- See signature
- North Somerset
Time for that 2.4m to go up?
It will help, but the problem will not go away entirely. I seem to be living in a similar spot, just further south east. My dish is set to 2E, ITV HD and Channel 4 HD are somehow affected more than BBC Wales HD and Channel 5 e.g. because of the strong EU beam TP close to them.Time for that 2.4m to go up?
Yes, that would be a nice excuse to bring it up...Time for that 2.4m to go up?
Come to think of it, I'd probably re-tune the CM180 for 2F/G@28.2E for the HD stuff, and the CM120 for 2E@28.5 for the easier-to-receive stuff...As an alternative, in the past couple of weeks I have been toying with the idea of keeping the CM180 on 28.5 (which it is tuned to now), and then have a CM120 on 28.2 for the low-FEC SD channels.
If I had the space and money I'd go for a two dish setup. Maybe overkill and expensive but at least you can track both positions accurately.Come to think of it, I'd probably re-tune the CM180 for 2F/G@28.2E for the HD stuff, and the CM120 for 2E@28.5 for the easier-to-receive stuff...
Can you get channel 5 when BBC1 NI drops out? If you can I would suggest nudging dish to the east. At the moment I am in BBC mode the sky is clear and am getting 71% on BBC1NI 63% C5. How do your levels compare?Have a gibby 125, receiving bbc 1 NI until ~1830 CET winter weather conditions, am contemplating investing in a gibby 150, are there very big differences/signal gain to justify this swap?
Regards
My numbers were SD but just checked HD and it's 71% BBC1NI HD.We don't bother much with HD due to watching/recording conflicts. I'll watch to see if my signal drops later.BBC 1 NI HD @10847v on my spiderbox 6000 HD reading 805 qual 63%, channel 5 ( locked before ) not locking ATM. Clear sky and sun.
Regards
The spider ( out 43-44% ) knocks spots off my Techno 5402 hd mk2 ( out 53 % ) and the ageing Hummy ( out not measured ), not a motorised setup, max 10 meter coax run from dish to box ( will check it when the snow melts and the weather gets warmer ), LNB brand new last year
GI-212E twin LNBs
( surplus from Member Captain Jack ) better qual than both maximum, inverto black and numerous other LNBs ~3% gain ( from memory ).
Live close to the supposedly "" first null "" central southern Norway
Will not order the gibby 150 until present system checked
Edit Sold - 4x GI-212E twin LNBs
Spider box going on my shopping list. Been dying to hear of a box that's been proved better than a TM.
Unless someone knows of a box that beats the spider?
