Newsnet on Ka Band A
Still nothing down here in Somerset. :-(
..... bet they have tightened the spot beam up matey, there on to us, we've been rumbled, were doomed , were doomed :eek::)
Archive-8
Hmm that's bad news, let's hope something changes for the better.
I might try and test my lnb via the 42e mux.
Back up and locking this morning. Phew!
Still low dB's though.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Trust
Nijmegen Netherlands
Right now with CM 1.8 and SL3K 12.0 dB
Can't be a beam change surely, as I'm near Uttoxeter UK and Trust in the Netherlands..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Fractional improvement ..
now 6.8db on the F15
Hughes linearV offset 3 degrees from focus on my 1.5m
so comparable I guess with Scopus results in Staffs..
I know I'm fringe here in west of Manchester.
See Llew for details.
lol
...rule of thumb ...the further East you go in the UK ..the better the signal..
We could do with getting reports from all over the uk ..and the relevant European countries ..and try to pin down the centre of the beam ...
My guess would be just to the East of the UK ..somewhere in the North Sea...
lol
John must have some sort of other problem, because he is more east than me in Mansfield, he got bugger all this morn he tells me...
I perhaps should have added that i was in jokular mode lol
Archive-8
Well I have changed the omt, and changed the polarity to horizontal, and I have a picture:-) on the nags 18769 H 3110 but the best I can get at the moment is 4.0 db on my dr hd d15 :-(
Can some one please report signal levels for this transponder?
Many thanks.
Well I have changed the omt, and changed the polarity to horizontal, and I have a picture:) on the nags 18769 H 3110 but the best I can get at the moment is 4.0 db on my dr hd d15 :-(
Many thanks.
Keep tweeking Chris, iv'e just lashed up a SL3 that i modded a while back but never used, and it's not 100% tweeked for max on the 1.8 CM but it can't be far off because the nag feed is coming in at 18.2dB.
The Newsnet ladies on Vert was 14.2dB
Lets have a piccy then??
13dB on the Hughes LNB on a 1M Triax Chris.
Doing well there John, 15.7dB for me with Newsnet ladies
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Newsnet ladies Hughes linear on OMT = 7db atm V
Nag feed Norsat 9000A linear on OMT = 12.8db H
The temp SL3 lash up ... the XMW off to sunny South Korea for fix :(
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Just a thought John ..
My XMW bought from Jin ...but for KaD coverage did once get wet inside due to excessive rain and a hairline crack in the Aluminium casting...
Rather than send it back I opened it up ...dried it out an re-sealed everything with silicon grease..
Worked fine afterwards and that was a couple of years back..
