Entitlements for Sky UK is for UK only.
steffan_st
A bit enthusiastic
Gibertini OP 125 L, Smart Titanium lnb with CD-80 feedhorn, Moteck SG-2500, Azbox HD Premium+, some 5 meters of good quality coax
Sweden
Lately I've been having problems watching BBC four HD (11.024 h) during the evenings over in s/e Sweden . Anyone else noticed?
Nalleman
Motala Sweden
Sweden
No problem with netiher 2G nor 2E/F here!
skomedal
This and that
thule
Does seem size matters after-all!
steffan_st has a Gibertini OP 125 L,
Nalleman has a 1,8 Channel Master,
Re posts 502 & 503 My satellite setup left pane
Myself I stream in the evenings:eek:
Regards
Tururu
Assembled with recycled parts
Recycled as the owner.
As usual levels by Madrid (Spain) with 100cm antenna.
Los niveles como siempre por Madrid (España) con antena de 100cm.
A greeting.
Alistair_
Gibertini 1.5mt
Inverto Ultra
Amstrad DRX895
Pace2600
N. Italy, 40km E. Milan
Only BBC4HD? How about ITVHD, Drama, Seven4.. those alright?
Alistair_
Gibertini 1.5mt
Inverto Ultra
Amstrad DRX895
Pace2600
Wow. You receive BBC4HD from Madrid with just a 94cm, which LNB are you using?
No LNB can make up for lack of dish size. We can get almost everything here, 450 km south east of Madrid on a 1 metre dish. Go 100 km further south and a 1.4 metre dish is minimum. ITV HD requires a bit more dish due to the reduced error correction.
Alistair_
Gibertini 1.5mt
Inverto Ultra
Amstrad DRX895
Pace2600
I have 50% more dish than you and I can't get everything, you must be in a lucky area as you're definitely further away from the UK.
steffan_st
A bit enthusiastic
Sweden
ITV HD is impossible at my location nowadays, since FEC=3/4.
Maybe I should start looking for hardware issues. BBC 2 and four HD are the only channels of interest to me at 28 degr. btw.:)
Archive4
Go another 10 km, 1.8 m, 30 km more 2.4 , any further due south IPTV!
steffan_st
A bit enthusiastic
Sweden
Thank's Nalleman, I better spend this evening at the balcony=major overhaul of my setup.
Tururu
I'm at a point with signal peak in San Sebastian de los Reyes (Madrid) in San Fernando de Henares, or 30 kilometers further south, with the same antenna, nothing.
Currently with Inverto Black Ultra 0'2dB.
No problems with an old LNB LIDL supermarket 6€uros, with the new more stability in the evenings since removed the Astra 2D.
Overall for Madrid, 150cm minimum recommended not to have probem with bad weather.
Estoy en un punto con pico de señal en San Sebastian de los Reyes (Madrid), en San Fernando de Henares, ni 30 Kilometros mas al sur, con la misma antena, nada.
Actualmente con Inverto Black Ultra 0'2dB.
Sin problemas con un viejo LNB del supermercado LIDL de 6€uros, con el nuevo mas estabilidad por las tardes desde que quitaron el Astra 2D.
En general por Madrid, minimo recomendado 150cm para no tener probemas con el mal tiempo.
PS:Some pictures of 2011/Unas fotos del 2011.
Nalleman
Motala Sweden
Sweden
Hope you can solve the problem! Maybe I should have written there is no change at all in signal level during the last months at my place. The only TP which comes in very low is 12 304H and if FEC changes to 5/6 I will probably loose this TP but it doesn't matter to me.
