40.5ºW SES-6 first scan with new dish.
drhans
drhans.tv
C-band: CM 240cm PF 34W-50W linear Avcomm feedring & OMT + 2x Astrotel Precision LNB & circular Avcomm polarizer + Zinwell LNBF, IRTE 180 cm 1W-34W + ESX241. DM820HD, VU+ Zero, DM500HDv2, Cisco D9865 AFN, TBS 5925 & 6983, XFinder
Prague
Yes, still on air, got it on 3723 L
thanks, can you please tell me what dish size did you check with and how strong the signal is, compared to 3712 L and 3735 L? I can get both 3712L and 3735L with 8.5-9.5 dB
Anonymous_1
I use a 1.80m antenna and a Titanium
3710 L 7400 7/8 : 8.1 dB
3735 L, no lock (not find in BS)
edit: Signal:
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
trouble finding any on this sat, do i need the plate in or out?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
''You need the plate in. Plate in = LR polarity''......thanks Chris and talking of 'Polarity' my scan early this morning shows I need to move it!! :D
Apologies for the Polarization being in reverse.
Some 70 transponders but still a lot missing and a few mins later added and lost a few to the first scan. ;)
3628 R 2170 Brazil - http://redeuniao.com.br/novo/
3849 R 2800 DAT TV - Venezuela
3883 L 1837 Tele Vid - Colombia Televid.TV - Programación
4130 R 3844 City TV - Colombia
4196 R 2960 TV Novo Tempo Rio Grande do Sol - Brazil
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
hello.
what about today?
4544 R
DVB-S2/8PSK
HEVC
SES UHD and NASA UHD.
are they Hemi West or East?
tnx!
WHATAGOAL1
Leic
could some kind soul post strong transponder. Have moved dish and lost my bearings.
40.5 West.....
4097 LHC Footy, fta.
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
@John, what about 4544R?
Do you need an extended lnb for that? It's beyond the range of the normal c band one.
For peeter and CJ,
That's correct CJ, i have one that's set up for circular but it's not on the dish at the moment but will re-fit it very soon :)
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
have somebody "inside inform" about 4544R, is it on West or East Hemi? (I think it is in West, so needs 4-5m antenna or more)
Feedsat_DXer is the one to ask or answer really. I have received the 4544 RHC mux here in central UK with intermittent lock on my 1.8 CM off-set, but only just .
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
I just have one 2.4 or 2.7m antenna to use.
like this
Anonymous_1
Yes, Cband extended frequencies can be received here , exactly in the same way as the regular Cband frequencies.
Qwer_DX can show you some screenshots with his 5m antenna, my 1.80m is TOO small for this position in Cband and the my 3.10m antennas are not able yet to see this position.
Interesting. As I'll be getting an LNB rotator sooner or later, I might attempt those extended c band frequencies. Whether the 'tiny' 1.8m dish is enough, remains to be seen
Anonymous_1
Well, after reading my contribution: I mean too small for a good C-band extended lock with 1.80m but of course I can lock most of the C- band frequencies .
4544 R is in 8PSK 5/6, signal higher than 9 dB is required and 1.80m is not big enough .
Yep, understand.
