Something from around 50E!
Ive just blind scanned this signal in & Ive got myself in a muddle trying to work out which bird its coming off!
10718H
3750 auto
Channel id is TEST on the epg But the channel is 4UIranian.
It must be from Turkmensat. The signal is very strong here in the North of Turkey. Berlintersat also use this frequency range, but I don't think the signal from it can be so strong here.
4UI needs to update their FB page - it was last updated in December!
11.5 dB on 52.0 E
10.4 dB on 52.5 E
8.3 dB on 53.o E
Did not have time to check below 52, ie 50 e, never got anything from 51.5 so I doubt it´s that.
EMMERDALE is on now, tests suspended!
11.5 dB on 52.0 E
10.4 dB on 52.5 E
8.3 dB on 53.o E
Do you prefer dubbed or with Turkish subtitles .
14.7dB on the 52/53E dish (80cm)
10.0 dB on the 50E lnb 1.1m (offset lnb on 46E dish)
I would say this rules out 50E Turksat.
I have just checked my mutifeed system on 50 degrees (Turksat4:cool: and I could still get the signal (very weak) . I could not get any other signals from Turkmensat.
There are only two options frequency planwise, either Berlintersat or Turkmensat. As the signal is very strong in Turkey, it is most probably Turkmensat but we cannot be sure until someone compares 52E and 51,5 E.
I'll be very disappointed if it turns out to be the first transmission from Belintersat! :-rofl2
I have just checked my mutifeed system on 50 degrees (Turksat4:cool: and I could still get the signal. I could not get any other signals from Turkmensat.
Anything better to do this weekend?
I suspect you'll walk it :)
10718H
3750 auto
p
I have it.
Owing to local los restrictions and other evidence, I agree with those who think it must be 52E.
I, Sir, have been watching Masterchuff.
