Vipersan
Emmett Browns Ghost
- IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
- UK
Similar issues ..perhaps a little worse at 25E ..Yes, that screen looks right for 15W. I had to download VB cable as no sound card was showing up in Jaero.
LHCP or RHCP makes not difference for me either.
Basically the noise floor is too great I think ..
The signals are there but dont rise above the background static ..
Perhaps there is a more suitable splitter as I cannot use the TBS loop through..
any ideas ?
Just a thought ..
If RHCP or LHCP gives the same results ...and the signals _are_ circularly polarised ...then insufficient conversion is taking place imo ...and valuable signal is being lost ..
2 halves if fully converted would make a whole ..
