- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
I can post out what I have on Tuesday
Appreciated buddy ...but only if surplus to requirements..
This project is fast becoming a never ending stream of outgoing cash ..so need to put the brakes on a bit..
lol
I'd appreciate you taking a look at the moonraker in the add ?
Cheers CH ..Looks like the one I have. I bought it some 15 years ago and from memory, it was only suitable for the 900MHz band
Well ..I guess that answers my question then ...
A thing made to do everything ...does well at nothing ..
lol
unlike my trusty QFH ...made to do a specific job ...and does it well..
As far as upgrading this rather nice SFF dell is concerned I'm now maxed on memory ...so was looking at the cpu..(socket 774)
Installed cpu-z and had a look whats in the box ..
Pentium D 930 which is dual core ...not core 2
Core 2 architecture is not supported ...and I'm already close to max with this ...
I can only now upgrade as far as a Pentium D 960 ....
Question for those in the know ..would this upgrade make much difference ?
The reason I ask is that the D960 is like hens teeth ...so getting one might be an issue.
But if the upgrade is worthwhile ..I'll keep looking.
rgds
VS
Must be slow this morning ..You broke it inside a fortnight ?
be careful with cpu-z... it's well known to be a "open port" for adware and trackware connections.Installed cpu-z and had a look whats in the box ..
