40.5ºW SES-6 first scan with new dish.
Some activity on 40.5West Extended Cband LHC. Womens footy.
4630 LHC. 29999. on the NET TV Promo channel40.5 West...C band Extended.......reduced..jpg 40.5 West...C band Extended.....reduced..jpg
LOF out on this Amiko A3 .... should be reading 4640
@ peeter , i'll try and find time to change the C-extended to RHC today and see what strength it comes in at. In the past i have managed to get very intermittent lock occasionally but really needs a bigger dish as Feedsat says...... i'll give it a go anyway. ;)
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
Hemi West signal must be not more than 20-22dbW (?) in UK , needs then 5m dish...?
And East signal is 40dbW, needs 110cm-150cm.
FlySat SES-6 @ 40.5° West Beams
40.5 west. Ext-C. 6983 card, RHC. Freq 4544- 8.1dB..reduced....jpg 40.5 West ..Ext Cband Circular.... reduced..jpg @peeter ... this info is for a CM 1.8 offset, using a ADL / AVComm poloriser barrel into a JRC extended C-band lnb located just north of Nottingham UK and looking at the East Hemi footprint.
Just as Feedsat reported, 4544 RHC just does not quite lock with 8.1 dB and just needs a bit more , the weather here has been overcast all day and might have a very very slight effect. I will continue to monitor RHC for a few days and document dB levels.
Receiver choice has an effect as well, my TBS6983 pc card did not capture as much as my Amiko A3 did. I will try another receiver as well like the TM5402 HD Mk3.
The difference in levels from LHC to RHC can be seen in the analyser grabs.
40.5 West ..Ext Cband Circular on Amiko A3..... reduced..jpg 40.5 West ..Ext Cband Circular on Amiko A3..... reduced..jpg 40.5 West ..Ext Cband RH-Circular...reduced..jpg 40.5 west. Ext-C. 6983 card, RHC. Freq 4544- 8.1dB..reduced..jpg
peeter3000
125x140cm Mabo
3m AerialAS30,
80cm Triax
TBS5922
CrazyScan 1.0.1.94.
(Lenovo T420)
Estonia(EU)
now 4544 needs HEVC TV and 2.0m+ antenna..
I still dont know what signals will be here with 2.4-2.7m mesh antenna.
.. I just need One more dB, that's all thats in between me not seeing a lock , Hmmmmm now where can i find that from ?? lol
Ohh so close to the required magic 9dB.
Had lock at 8.6 dB .... just, with sound and picture break up but un-watchable :(
If only somebody made a 2mtr off-set just to get me that little extra lol.
40 West Circular R....jpg.
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
found it, thanks Chris1979, managed to scan in 150 channels, strange though your strongest is one of the weaker signals here in the midlands.
It measures 5.6db 40% using tm5402, i have others 12.2db 86%(3679v)
pride21
Sandown Isle of Wight
hi all did a scan of this sat new transponders for me EL GARAGE TV 3877L 3702,AGROBRASIL 3628L 2786,3770L 21600 5 channels scrambled,4106L 4699 all the channels scrambled and an odd one 3680R 4343 all its got is UPDATE.
lost_mesa
8 ft and 10 ft dishes. microHD receiver
New Mexico
Here in the States, I can lock 3 extended C Band signals on SES-6. This is with a 3 meter dish.
4641 L 30000 SNR=8.2 - Net 264, 1 channel
4581 L 30000 SNR=10.3 - Viacom, 17 scrambled channels
4543 R 20659 SNR=8.1 - 4K uHD, 4 channels
The C Band channels on Eutelsat 65w A are, as far as I know, all in the 4500 to 4800 MHz range. Conveniently, it has been testing next door to SES-6. But I haven't seen any activity there, other than a unmodulated beacon at 4800 MHz horizontal, and that disappeared few weeks ago.
WHATAGOAL1
Leic
could someone explain the term"extended c-band"?, and what lnb is needed?
Normal C band coverage for us enthusiasts is from 3.400 to 4.200 with signals either H, V, LHC or RHC and generally uses 5.150 LO as you know. "Extended C band" is a term loosely used by us enthusiasts for the reception between 4.500 to 4.800 with a LO of 5.75 (mine is 5.76). I can receive and just lock LHC sigs on 40.5West on my 1.8 CM offset ..... RHC sigs will just not lock for me. Ideally 3metre dish or bigger for good solid signal locks. There's not a great deal to look at on Extended C band for us meer mortals with small dishes and standard basic receive equipment but it's exciting to try.
Google search for Extended C band lnb and it will bring up some hits.
WHATAGOAL1
Leic
well just changed 5150 to 5750, blindscan, thought i had found new channels, but they were just repeats of what i already had, but with transponder frequencys higher
Wouldn't it be nice to just alter the LO, sadly not tho :).
The one i use as shown in the pic is a JRC , other types are available from Norsat, SMW etc
My blind scan today - 63 lockable transponders
Screenshot 2016-05-31 10.11.44.png Screenshot 2016-05-31 10.09.14.png Screenshot 2016-05-31 10.09.37.png
.... would someone with Extended Cband check 4544 R on 40.5 West please. Scanned it this morning showing the usual thats there but my 5402 Mk3 rx today identified the channel "TELESUR" as being present but would not capture or save it. "TELESUR" is normally on 4119 R.
lost_mesa
New Mexico
I'm seeing a signal at 4544 R, but it's too weak to lock. Isn't 4544 R the SES Ultra HD Demo Channel?
Yep thats right. Strange one this, thanks for looking ;)
gafsa
180 c/ku band
tunisia
SES-6 @ 40.5° West
4040
4438
r
