Advice Needed Before I make a complete ass of myself again!
Archive4
Following on from the tests I have run in this thread New Lnb changer , and having read the links from it regarding " centre point " or as previously named in another thread " le G spot ", I have one simple question.
Should an offset dish lnb aim directly at the centre point of the dish, in the same way a prime focus dish does?
To explain it better, if a dish is 80 wide and 100 high, should the lnb be aimed at 40 from the left and 50 from the bottom? ( or 40 from the right and 50 from the top, whichever bursts your bubble )
I was thinking about asking the design people at Laminas why my laser spot is 40 mm below where I think it should be. But, as the title states..........
There's a formula to calculate where the LNB should point. It depends on the dimensions, the offset angle and the depth of the dish. Rimant will be along shortly....
RimaNTSS
Some SAT-related hardware.
N-E from Riga
NO!
@Captain Jack , when you mention me, you better put @ before my nickname, otherwise I can miss interesting questions :rolleyes:
Archive4
I wanted a simple, layman´s answer, centre of dish or not?
I don´t want to download a piece of software that will tell me I need to see a shrink, I already know that much :eek:
My CM offset was the same, ie: approx 40mm down from centre. My 1.2 CM offset also has a G spot lower than centre .... over to you Rimants
RimaNTSS
N-E from Riga
For CM 1,2m G-spot is about 115mm down from center. For another dishes can be different, but bottom line is that for offset dish G-spot is always lower than center. That is the beauty of the offset dish.
Archive4
Why make the dish so big then, if g spot is 115mm below on a 1.2 m dish, may as well be a 90 cm dish?
From space, an offset dish looks round. So a 1.8m dish that is 1.8m horizontally and 2.0m vertically appears as a round 1.8m dish. This is because unlike a prime focus dish, that looks directly at a satellite, an offset dish looks at the satellite at an angle (the offset angle). It's that angle that causes the vertical dimension to look smaller than it is.
I think........
RimaNTSS
N-E from Riga
I think........
You think perfectly right CJ. On attached picture green line shows direction from satellite to the dish and it hits to the G-spot, which is not the center of the offset dish.
Archive4
OK , on my Laminas 1.8 m dish the G spot is about 40 mm below centre, so why is it 115 mm below on the CM 1.2 m dish?
RimaNTSS
N-E from Riga
On your Laminas 1,8m LNB is pointing 40mm below the center, but that does not mean that real G-spot is 40mm below the center (most likely it is even lower).
Archive4
OK , I sit corrected, what I was trying to say is the laser points 40mm below center when correctly sitting in the lnb holder made by the manufacturer
RimaNTSS
N-E from Riga
Yes, and this does not mean that manufacturer made it perfect. Do you confirm that working area of Laminas 1,8m is 1800 x 1935mm? If so, than G-spot should be located about 800mm from the point "B" (bottom point of the working area of the dish).
Archive4
When you say point B from the bottom of the dish, is this point B as measured round the dish face, or point B measured in a vertical line from top to bottom of dish, like this ( which I borrowed from lnb changer thread )
test-focal-jpg.92590
RimaNTSS
N-E from Riga
No, my pint "B" is quiet different from Wim's point "B". On the attached picture I circled my point "B" in "Navy blue" color. So, point "B" is the lowest point of the working area of the offset dish.
Archive4
OK I get that, but is it from point B directly vertical 800 mm or via dish face which would be approx 900 mm?
RimaNTSS
N-E from Riga
No, from point "B" directly to the point "G" = 800mm (red line on the attached picture).
Archive4
OK if I get this right, from point B to point G in a direct line should be approx 840 mm on a straight line across dish face and approx 937 mm allowing for dish indentation on a standard offset 1.8 dish?
