2 channel master dishes with motors (1 meter and 1.2 meter), 4 lnbs, 4 receivers - 2 echostar ad-3600 ip viaccess, technomate tm5500 and 1 echostar 3000ip
motorised satellite system job lot
90 cm fibo gregorian
FIBO 90cm gregorian motorised satellite dish
Irte dish with actuator etc
Irte 130cm motorized Satellite Dish including mount and pole
1.5M satellite dish, no mention of the brand but i thought i'd post it...
Satellite dish | Caversham, Berkshire | Gumtree
I've put a bid in on the two channel master's not bothered about the rest just interested to see what the motors are. Don't want to pay too much its only the motors I am after
good luck, hopefully you get a bargain :)
At least one of them looks like a Jack arm - the seller mentioned 18", which usually refers to one. I wouldn't mind one of those Echostars as they have a 36v motor control.
Went for £53.75
It went for £53.75 but unfortunately it wasn't me that got it.
someone got a bargain to be fair, better luck next time mate ;)
To be fair I don't rely need them, with two 1.2 cm a 15 IRTE and a 1.8 cm stuck in the garage. But if they had been at the right price why not.
yea when you get a bargain for the right price its hard to say no lol
btw the irte dish is still at £50 with one hour to go
1.2m dish with polar mount, motor, etc
and also a 1.8m fortec star dishes (i think its one of those)
£25
Satellite dishes, stand, motor, polar mount and bits | Dawlish, Devon | Gumtree
Not a Fortec star / Jonsa dish. The petals look much more like plastic, so maybe something more sturdy and worthwhile (unless there is no hardware, as stated in the ad)?
The 1.2 meter offset dish looks very much like a Northern Satellite Corp dish (ie. not a Channel Master or Prodelin).
Yes, most likely it is NSC 1,2m, however my measured dimensions of it's working area is 1206 x 1348mm and depth 131mm. And I do not really undderstand what "overall depth" mean :-doh $_86.webp
P.S. You will not believe.... I sold one of my dishes!!:cool: Now I have one dish less :oops:
Yes, most likely it is NSC 1,2m, however my measured dimensions of it's working area is 1206 x 1348mm and depth 131mm. And I do not really undderstand what "overall depth" mean :-doh View attachment 92793
Eh?? What happened?
A momentary lapse of reason?
