- Some SAT-related hardware.
- N-E from Riga
Wehrah, nahs. Wehrah nahs indeed.More or less finished painting. But, to continue, need some new nuts&bolts (not metric, so, not easy to find). Also need to find 2 end-switches. Need to finish mount (100mm square pipe). Will use original (very heavy ring) to attach antenna. I need to make hinge along red line and 2 declination adjusters (where I circled green).
@dan rose : I do not understand what exactly you mean.Rima what do you recommend for concrete or cement for a 1.2 and 1.8 meter dish?
What make are the dishes the attached are for channel mastershow much concrete or cement how many bags? I wanting to use a 3 inch diameter pole for a 1.2 meter dish or larger how much area from the base of the pole out?
I have an idea (yes, maybe it is too ambitious, but anyway...) to remove existing non-penetrating stand and dig a hole instead if it. The hole will be 2m x 2m x 1m filled with concrete. And those ~10 tons of concrete should firmly hold some big antenna.
