- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
From space, an offset dish looks round. So a 1.8m dish that is 1.8m horizontally and 2.0m vertically appears as a round 1.8m dish. This is because unlike a prime focus dish, that looks directly at a satellite, an offset dish looks at the satellite at an angle (the offset angle). It's that angle that causes the vertical dimension to look smaller than it is.
I think........
Which only partly explains the reason for having an offset design.
A parabola is a parabola whatever the cross section, any prime focus dish will have an f/d ratio that is set by one formula.
An offset dish is nothing more than a section of a prime focus version. Once you understand this it should all fall into place.
