I find it strange 5°E and 1°W are so problematic. Are these so much weaker there than in NL?I am rather annoyed that I cannot get 1w and 5e properly. Half the channels come in and half don't. These are not the strongest positions here anyway but Penta 85 has no problems with them (in focus). So on the edges, the T90 is equivalent to a 70cm dish-ish (on my setup anyway).
So... I can either bring the dish closer to the west to bring 1w and 5e more into focus but I will lose 39e - unless I extend the range with a bar of some sort. And potentially gain 5w?
How accurate is this site with its skew measurements? SatLex Digital :: Technology :: Calculators :: WF Toroidal Calculator
Yes, especially as you go further west. Signals on the east coast of the UK are strong for the Nordic beams but they start to drop off as you go west and CJ is quite far west.I find it strange 5°E and 1°W are so problematic. Are these so much weaker there than in NL?
If you have the clamps the right way round, that is...Same with 90 clamp, towards the front.For sure with the T55 clamp, the hole is NOT in the middle!
You can probably win an extra 1 dB or so by using IBU's instead of these cute baby-LNB's.
Looks like I have to start at the beginning....
All in the name of saving time. I mean, how hard is it to align a small ish fixed dish....Receive it, install it, scratch head, and only then.
They are and the signal level wasn't really any different from an IBU. I like these and they look tidy.The cute's looks like max xo-11's ? They are very good imo.
