s-band
- Feb 7, 2016
- Essex
I have been playing with an old band C LNB (20.2-21.2) and a linear offset feed on the 1.5m PF dish. It fits the C band (4GHz) scalar when very long screws are used. The LNB is a bit suspect as it seems to tail off above about 21G but it works well down to 19.9 and just about down to 19.7. I set the LNB to slant polarisation to catch V/H & circular.
I've found lots of data between 19E and 45W much of which must be mil. Some are strong including some very wide band sigs. I haven't found any TV in that range nor can I see any on Lynsat etc. Is there anything in that range?
