24.5W Intelsat 905
Lasseparabol
3 m Prodelin
C band 25K Chaparall Sidekick
Ku band SMW X-line lnb
Chapparal Corrotor 2 Wide band
Echostar AD-3000IP
Dr.HD F15
Sweden south part
Now RTS1 Senegal is at 3652R 3906SR 3/4, at lot weak than egypt txp on same beam.
Costactc
Canada
I know I'm across the pond but I lost Rtb Tv at 4122 R 5180 about 2 weeks ago. That's a bummer as it was the only tp at thos orbital location that I picked up....starting to age maybe?
Lasseparabol
3 m Prodelin
Echostar AD-3000IP
Dr.HD F15
Sweden south part
It´s still were but very weak, i only get 3.0dB
pride21
Sandown Isle of Wight
P5190008.jpg this is a first for me on 4122R RTB very weak
Costactc
Canada
I managed to get RTB to scan in once again with stable signal quality on my x2 premium:
No sign of it here. Does it broadcast 24hrs a day?
Costactc
Canada
I'm not sure if it broadcasts 24 hours a day but always seems to be on when I scan 24.5w.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Still there for me too ...but a helluva lot weaker than it used to be ..
No problem here.
pride21
for me personaly I found early morning was the best time to get this channel then it gradually fades
Zilch here this morning... :( The Egypt channels don't seem to change in signal strength throughout the day.
Archive-8
[SATTYPE]
1=3355
2=C-Band Intelsat 905
3=3
4=0
5=5150
6=0
[DVB]
0=22
1=3633,H,1479,56,6,|-55 dBm, 3 dB
2=3678,H,1994,23,134,|-55 dBm, -0.7 dB
3=3736,V,19580,34,132,|-53 dBm, 1.7 dB
4=3756,H,1777,34,6,|-52 dBm, 1.7 dB
5=3791,V,13750,34,132,|-53 dBm, 2.2 dB
6=3791,H,13750,34,148,|-52 dBm, 4.2 dB
7=3822,V,16290,56,148,|-53 dBm, 4.4 dB
8=3836,V,1332,23,5,|-54 dBm, 0.6 dB
9=3920,V,29990,56,134,|-52 dBm, 0 dB
10=3920,H,29990,45,132,|-53 dBm, 3.8 dB
11=3968,V,10830,34,132,|-54 dBm, -0.8 dB
12=3968,H,10830,23,132,|-55 dBm, 2.5 dB
13=4000,V,29990,34,148,|-54 dBm, -1.2 dB
14=4000,H,29990,34,148,|-55 dBm, 1.5 dB
15=4037,H,14250,34,132,|-55 dBm, -1.5 dB
16=4049,V,2539,78,1,|-54 dBm, 5.9 dB
17=4100,H,29990,89,150,|-55 dBm, 2 dB
18=4100,V,29990,89,150,|-54 dBm, 4.4 dB
19=4140,V,29990,34,134,|-54 dBm, 3.9 dB
20=4160,H,29990,45,132,|-54 dBm, 0.3 dB
21=4194,V,6498,34,6,|-57 dBm, 1.3 dB
22=4194,H,6498,34,6,|-56 dBm, -2 dB
Archive-8
[SATTYPE]
1=3355
3=4
4=0
5=5150
6=0
[DVB]
0=6
1=3688,V,21050,23,1
2=3715,H,3579,?,4
3=3722,H,1927,?,4
4=3728,H,2753,?,4
5=3891,V,9413,23,134
6=4071,V,3797,12,1
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
are tthese using a 1.8 or less?, not having a lot of luck
24.5 West right now ..... This is quite strong as well, 3688 R. on the documented feed list.
Rx on 1.8 CM Offset.
Today's scan. RTB doesn't seem to be there any more?
That was it. Not getting this frequency either.
Lasseparabol
3 m Prodelin
Echostar AD-3000IP
Dr.HD F15
Sweden south part
CIS TV new to me, 3662R 4880 1/2 at 5.9dB
Ertu 3688 no signal.
