- Aug 10, 2008
- Romania
#79-I speak only about TBS cards I've checked myself:6983,6908,6925.But best to lock the signal for GS and record is TBS6983 and also TBS6908.
#80-Not all Generic Streams contained media;or rather, they are like some feeds,they are not regular transmissions.Their contents change continuously depending on the needs of the provider.But the most important thing to know is that these continous streams are not viewable with our tools,for hobbyists.For that it needs a dedicated demodulator and a special software,which only the recipient owns.
The only hope that we, as amateurs, is to find stream with a Data Rate very high,let's say more than 300 kbps, but it is better 800 or 900 kbps.Therefore, the data rate is greater than the better emphasize the content,i.e.meaning that the image could be viewable.Unfortunately, even in this situation, the data rate is not kept at the same level,decreases continuously,as for appearing pixelation,the image is broken,after which no longer see anything but blocks of color.
In short, so far these streams are more a curiosity for us as long as as we do not have the right tool,although this type of transmission will be used more often in the future.
