Help Required crazyscan qt dll
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
just got a tbs 5925 and trying to install crazyscan, but will not install because qtcore4.dll and 3 or 4 siniliar are missing .
Can anyone show where they can be downloaded.
Also what is the streamreader and where to install would be great.
WHATAGOAL1
Leic
hvdh, many thanks, loads now but 1 error comes up"RFscan2 not supported", do you know what it means or how to correct it?
I'm not sure, I think you must use the normal CrazyScan.rar, not the CrazyScan2.rar.
Did you install the required driver for the TBS 5925 already?
Crazyscan2 is for DVB-T and cable cards. As hvdh says, change to Crazyscan.rar for DVB-S and S2 cards, like your TBS5925.
WHATAGOAL1
Leic
I am fool used crazyscan2, you are both correct, now i have to change streamreader back, it is a long slog
WHATAGOAL1
Leic
it is too much for me, now I get error "streamreaderEX init error "
This is what you should find in the Crazyscan folder.
And again, did you install the TBS 5925 driver at all?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
