- See Signature
- Somewhere in England (possibly?)!
After my own experience with the BEST switches it was roughly what I expected to hear, if not what I would have hoped to!
So, if anyone else has examples of those types of switches which do, or don't, work in a cascade setup, then it would be useful if they could give us their experience.
BTW: from what the guy at EMP stated (as above) it seems that a lot will also depend on which types of switches are used at which level. From what I have read/seen so far, there are a limited number of types which will work at the higher level (i.e. next along in the cascade after the switches to which the LNBs are directly connected), and those in that category are some of the more expensive ones which often have physical switches on them, or are programmable (IF you can obtain the programmer !), to change the modes in which they work - EMP have several, as do SPAUN - are there others?
