Advice Needed Does the VU+ Solo 4K Ultra HD have blind scan ?
sat-tv-fan
East Sussex, South East UK
(66 E) 42 E - 45.0 W
Azbox HD Premium
Azbox ME
Amiko A3 combo (android)
TBS 5925 and 5927 USB
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
Mecool K3 pro (android)
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Just curious and I guess it will deocde next years BBC UHD tests fine also ?
itchybag
1.1 stab motor with VU+ SOLO 4k, dm800, prof 7500
earth
it decoded there r&d test on 19.2 just fine. Supposed to be using HLG for a better hdr experience :)
sat-tv-fan
Azbox HD Premium
Azbox ME
GT Media V8
Octogan SX88+
Octagon SF8008
Koqit K1 mini
Openbox SX6 HD
X2 Premium HD
Skybox F3
Technomate 5302 HD
Technomate 5402 M3
iSmart X8
Great but does it have blind scan ?
Archive4
According to this review
VU+ Solo 4K Review - Linux-TV.com
it does have a blind scan option. But as the author of the above post has one, I´d be more inclined to take his advice.
I have a Solo SE and it performs a blind scan when asked, but seems to miss a lot of things that are there when you manually input the information from the signal finder option.
itchybag
earth
yeah it has the option but it doesn't work. you'll need to blindscan with something else then import those details. it doesn't do 16apsk or 4.2.2 either. It works fine with tivusat's recent Euro 2016 coverage via official card, softcams work. Its a denct receiver you still need a tbs card :)
drats
VU+Duo, Vu+Duo2, Vu+Zero, Gibi 1.5m, TBS 6903 PCI
North West UK
My blindscan seems to work fine on blackhole image
itchybag
earth
im on black hole 3.02 blindscan finds no transponder every time ive tried
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
No one has reported a blind scan that works dependably, easily, speedily and thoroughly on a Linux receiver on any image on any forum I have visited. Seems that Linux receivers are dependent on proprietary code being provided by the manufacturers and can only be run through a plug in. If this situation was sorted I would buy a Linux receiver without hesitation.
So the non-Linux receiver with Blind Scan is essential if you want to find live Hi Definition Feeds,
Maybe it is a conspiracy to prevent us finding these feeds so like 95% of the population who subscribe to the DTH satellites to watch live sport & are totally unaware that these broadcasts are often fta on another satellite only a few degrees from the one that that they subscribe to,
If they stop making Non Linux receivers as this seems to be the trend maybe they think we will have to subscribe this is why the Blind Scan on Linux is not fit for purpose,
Yet the Blind Scan on the TBS5925 Professional DVB-S2 TV Tuner USB is very good from what I have read here & elsewhere,
Why is the satellite industry no longer producing receivers like they did 10 years ago with all the latest features added,
Most of the boxes coming out of the Far East are just cheap simple receivers for PPV,
What we need is someone with a sense of adventure in this country to make a satellite receiver that can do all that the tbs chip does not rocket science.
itchybag
earth
yeah im still waiting for a dvb-s/dvb-s2/dvbs2x/dvb-s3/ns3/4 16/32apsk 4.2.2 avc compatible receiver :)
joking aside, even if my solo 4k could blind scan I would still use my prof7500 simply because it has a more sensitive tuner fo. fringe reception. then theres the likes of crazy scan. checking for rf spikes :)
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
So where are the Mr Dysons? An alternative is crowd funding. The question is, is the enthusiast market large enough to warrant the investment on a project like this. With the disappearance of What Satellite and Tele Satellite and the vastly improved speeds of internet has the market shrunk to far as to discouragepeople from being explorers of the sky?
One encouraging possible development is that Linux receivers can be used with usb professional tuners. I, for one, am interested in this possibility.
itchybag
earth
you can tuner share. A good example is the amiko hd mini's 16apsk and multistream compatible tuner can be shared via Linux to the solo 4k.
as for tbs making the ultimate piece of hardware, they are dependant on other chip manufacturerers, an example is Silicon labs who make demodulators and are used in tbs cards.
Actually the Amiko receivers are not bad blind scanners. I have an Icecrypt version of the Alien 2 running Spark2, finds most things and is quite fast. But it scans all the bands the only control you have you can scan V or H or both. I have never come across an Enigma version that works well with blindscan.
Tururu
Assembled with recycled parts
Recycled as the owner.
......Does the VU+ Solo 4K have blind scan ?
Como tiene procesar ARM, no va nada fino para mi gusto
Chequee un VU+Solo4K y la busqueda depende de la imagen instalada y la version que tengas.
En la imagen original del deco, la tiene.
BH la tiene en todas las versiones.
OpenSpa en la ultima no la tiene, en las otras como el resto, mal.
En general es mala y lenta la busqueda, el menu muestra la busqueda en los datos que realmente bajan del LNB (950Mhz-2150Mhz), si buscas algo determinado, tienes que tirar de calculadora y convertir la frecuencia del satelite - la frecuencia intermedia que restes.
Realmente es un sintonizador para ver la TV con sus 8 tuner de satelite (2-FCB*4) + 2 satelite/TDT/cable.
10 Tuner.
Para pescar, uso 2xVU+DUO2 (solo 4 tuner o no funciona) y 1xDB800S-HD.
Mantengo un viejo FTE Maximal para canales SD (muy bueno).
PIP 2 canales 4K (UHD)...No.
PIP reproduccion canal grabado + canal 4K(UHD)...No.
PD:
As ARM has processed, not doing anything for my taste fine
Check one VU+Solo4K and the search depends on the installed image and the version you have.
In the original image deco, does.
BH has it in all versions.
OpenSpa in the last does not, in the other as the rest wrong.
In general it is bad and slow the search, the menu shows the search in the data really get off the LNB (950MHz-2150MHz), if you are looking for something specific, you have to pull calculator and convert the frequency of the satellite - the intermediate frequency restes .
It really is a tuner to watch TV tuner with 8 satelite (2-FCB * 4) + 2 satellite/TDT/cable.
10 tuner.
To fish, use 2xVU+DUO2 (only 4runner or not working) and 1xDB800S-HD.
I keep an old FTE Maximal SD channels (very good).
PIP 2 channels 4K (UHD) ... No.
PIP channel playback recorded + channel 4K (UHD) ... No.
PS:
