WinRadio ?
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
That's an Icom R7000 not 700 and it does not cover HF. 25 Mhz to 2 GHz. TAH is also on 8431.
Check it on this online receiver
Wide-band WebSDR in Enschede, the Netherlands
A lot of broadcasters have disappeared off HF but China is there in force. As it happens Icom have just announced a new top of the range receiver in Japan. Google Icom R8600.
It covers the vast majority of bands used for high altitude/space communication, I posted it as you often get a bargain if there is a typo that is not corrected before end of auction.
The TAH broadcast is on a number of bands, including (from memory) the 4MHz maritime band
dxhound2003
Az Box Premium.
Dundalk Ireland
Someone got a good bargain there, if it is in good condition. I have the R7000, away in storage at the moment. They are built like a battleship. I also have the Win Radio receiver, again not in use. If I was going to go the PCI card receiver route again, I would get an outboard USB version, much more flexible as regards location.
My main HF receiver is a JRC NRD525. I might treat myself to one of the new Icoms if it is anyway reasonably priced.
The two I mentioned earlier from auctions
Icom 725 - needs a repair if I ever decide to transmit, and a Yuasu FT101 (E) which replaced a Lafayette HA800 for my evenings entertainment.
This dealer appears to have the 'Z' version up for grabs, untested though.
CLASSIC YAESU FT-101Z TRANSCEIVER
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Hidden Morse Code signal on Tubular bells ... 16.1khz GBR
Watch the whole clip to the end ..
s-band
Essex
...and I though t that I was a sad person. It's good to know I'm not alone.
Try the same thing with Brothers in Arms and you should find the 15625Hz presumably from a TV monitor
If you're into VLF, this comes on every now and then: SAQ Transmissions – The Alexander association
Christmas Eve may be the next time
.mp3 is tune-up followed by ID and message recorded using Spectrum Lab and a 4" ferrite rod antenna.
  • saq_0759_24-12-12_audio.mp3.zip
Fortunately I only have the LP.
Plenty of other tracks out there with satanic messages or 'easter eggs' within them.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Excellent ...Neil was soooo coool dude ..
I can only just top that one ...
..best watched in full screen mode...
That's 'Bad', though not as bad as this
That looks a pretty faithful rendition of how he looked towards the end of his life to me.
As good a place to put this as any.
RustySpoons
Sleepy Hollow
50E - 30W
2x CM 1.2m Polar Mount/Jack
65E- 65W
Mutant HD51
Edision Primo IP S2
Dreambox DM800HD
Venton Unibox HD2
Sony Bravia 55" 4K
South Wales
Just noticed this as the thread got bumped, looks a nice bit of kit that WinRadio.
I did have an SDRPlay which was a cracking bit of kit, can't imagine how much better that WinRadio is.
I've currently got a Yaesu FRG-8800 (With VHF module) on the workbench, seems like it has lots of issues.
Got the PLL circuit working with a new transistor and some adjustments, but the CPU is still locking up occasionally.
