twingang
- Mar 14, 2016
- Age
- 75
Fortec Passion box.
Dell Dimension desktop.
- Essex coast
Hi! fellow members. I have a WD elements USB HDD which was used with an Ice crypt 3250 and therefore formated by that stb.
I had found that using the above Hdd with my Gigablue Quad plus (depending on the image used) became erratic as
sometimes I was able to access the recorded files & other times not, sometimes I was able to
record & other times not.
My question is as follows: will I have to save the files that are on the Hdd to my PC & then
Re-format the Hdd or is there another way, as I would like some of these files to remain available on the above Hdd ? Many thanks
