Trust
- 1.2 m Echostar at Twotec twinrotor with lnb changer
- Nijmegen Netherlands
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Nice work , I assume youre not planning to use C lnb at the changer .
At the pictures from the beginning I was wondering if there is enough space for the C conicle horn .
With the earlyer motor position and cutting of the feedarms it would be possible tu use also C band
I have 2 x 1.2's from my old mate Jason at Rugeley Aerials...
do I see press cable lugs ? smart !
Whats the rod made of ?View attachment 96087[/QUOTE
... 6mm steel rod Wim, with a groove cut into it all the way around for the crimp lug to get a grip onto. A heavy duty crimp tool was used to really get a good purchase onto the rod.
Heat shrink over the rod, followed by a final adhesive shrink tube for the ends. Iv,e swung on the rods and pulled them and there nice and solid. To add some self confidence i have mounted / positioned the rods so that they are slightly in compression ie: they are not pulling "up" on the lnb boom arms.
Great stuff..Rugely Aerials was where our Sky dish came from originallyIts my parents old 60cm round ex analogue dish and the branding is just about still visible alyhough its 20 years old. Its probably the only Rugeley Aerials dish outside the Midlands
If we ever move it will be moving with us.
Will do...Next time either of you talk to the guys at Rugely Aerials you can tell them one of their branded dishes is now in use in Scotland![]()
Looks good.... control stuff for this Gibby 1.25 Ka install: Installed mainly for the aux rx for 18GHz Newsnet with a band D Inverto Ka/Ka thrown in as well. Limited arc travel. Main Ka duties are from 1.8 CM.
Contol kept nice and simple ....
25yr old Blast from the past Uniden 771 positioner.
TM-5402 HD M3 rx & TBS 6903 pc card.
Modded Global active splitter fed from rx "lnb out" ...... one output to specky, one output to 6903 card. Other half of Global to control Diseqc changer motor.
Stab mini diseqc controller.
............................................................................................................................................................................................................................................................................................................................................Looks goodis it fully automatic? Like some have done?
Looking forward to the signal reports.
Nice work John. Let us know the outcome, particularly the Ka test figures.
Interesting, is that saying that the CM is not so good for Ka? or does the TM5402 give you SNR rather than dB RF? If so, do you know the law for dB SNR vs dB RF? Theoretical difference, based on size, is 3.5dB. At that level, 2dB SNR is approx 3.5dB RF on my TBS for QPSK suggesting that you are getting good results if your dBs are SNR.
