The Aero Thread..
spacedish
1.8PF
90cm Greg
90cm offset
Ka mil lnb
numerous receivers
S band
north west uk
Hmm dunno why all that lot was crossed out ???
spacedish
1.8PF
90cm Greg
90cm offset
Ka mil lnb
numerous receivers
S band
north west uk
Here we go , they call it the magic line...
One plugin:
<add key="AuxVFO" value="SDRSharp.AuxVFO.AuxVFOPlugin,SDRSharp.AuxVFO" />
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Thanks guys ...
will be trying this out tonight on the 25E dongle first.
Confucian
1.4m Offset, 1.8m Prime Focus for C Band Aero
Dalystown, Ireland
One plugin:
mine is in the "plugins.xml" file which looks like
<?xml version="1.0" encoding="utf-8" ?>
- <sharpPlugins>
<add key="AuxVFO-1" value="SDRSharp.AuxVFO.AuxVFOPlugin,SDRSharp.AuxVFO" />
<add key="AuxVFO-2" value="SDRSharp.AuxVFO.AuxVFOPlugin,SDRSharp.AuxVFO" />
<add key="AF DNR" value="SDRSharp.DNR.AFNoiseReductionPlugin,SDRSharp.DNR" />
<add key="IF DNR" value="SDRSharp.DNR.IFNoiseReductionPlugin,SDRSharp.DNR" />
<add key="Noise Blanker" value="SDRSharp.NoiseBlanker.NoiseBlankerPlugin,SDRSharp.NoiseBlanker" />
<add key="Wave Recorder" value="SDRSharp.WavRecorder.WavRecorderPlugin,SDRSharp.WavRecorder" />
<add key="Zoom FFT" value="SDRSharp.ZoomFFT.ZoomFFTPlugin,SDRSharp.ZoomFFT" />
<add key="Frequency Manager" value="SDRSharp.FrequencyManager.FrequencyManagerPlugin,SDRSharp.FrequencyManager" />
</sharpPlugins>
Do you want me to fix the crossed out stuff in that earlier post it then tidy the thread up sd (removing your subsequent post & this one)?
spacedish
1.8PF
90cm Greg
90cm offset
Ka mil lnb
numerous receivers
S band
north west uk
No its OK thanks , just wasn't sure what I had done wrong.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ...looks like this will be a bit more involved than I thought ..
Mainly because I am using an older version of SDR# that is still compatible with SDRplay ..
..and the version of # Im currently using was built with an earlier runtime library ..thus the plugin fails to run.
Could one of you kind gents please tell me what version of SDR# is needed ...and either a link to it or upload it to a drop box or somesuch..
s-band
Essex
I used the one that came from Airspy Download I'm not sure which version as I can't get to the PC. However, I have not tried it with JAERO and an RTL stick. Everything else is ok with the RTL though. I have multiple versions of SDR# on the same PC in separate directories.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Cheers Graham ..
I'll give the latest a go ..
As you say ..I can run multiple different versions ..
rgds
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So downloaded the latest 1.0.0.1457 ...and it doesnt appear to run with RTL-USB ?
Have they dropped support for anything other than Airspy I wonder?
What version are you using Confucian ?
s-band
Essex
Mine is 1.0.0.1443 See PM for link
G
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Got some work to do to make this all work together now ..but at least your version is running G ..
Recognising the RTL-SDR dongle
Many thanks..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well I _think_ I have got the hang of it ..
see attached screen grab ..
s-band
Essex
Does this look ok guys ?View attachment 96940
Looks OK. I'm not sure about the audio outputs as I use VB-Audio virtual cables but if it gets to JAERO then it must be OK
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
It is using VB cables G ..
Virtual cable 4 to be exact ..but Left and right channels merged on VB4 I'm hoping ...for the two vfos ..
..and 10500 bps burst x2 at Jaero..
I'll untick L for a while ..and see if any data is transferred ...
Then test R in the same manner..
54W uses VB2 ..
15W uses VB3
25E uses VB4 Left and Right ...
VB1 is reserved for 15W Lband ...from the Homebrew Helical..
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Not the best time of day to set up multi channels ...
Targets are a good way off optimum relative to the equator ..
15W is more or less active with 2 channels left and right ..
Multiplexing GES43 and GES 44 T channels ..so I'm pleased so far ...maybe later tonight I'll try 54W ..
rgds
VS
Confucian
Dalystown, Ireland
1443 but I think you can add the SDRSharp.RTLSDR.dll from older version and <add key="RTL-SDR (US:cool:" value="SDRSharp.RTLSDR.RtlSdrIO,SDRSharp.RTLSDR" /> to FrontEnds.xml and the new version should work
Download latest version (1464 as i type) then download and install Modified front end from List of SDRSharp Plugins - rtl-sdr.com and all works ok.
s-band
Essex
Confucian, Thanks for the info but the code was corrupted by the board software. Try the "Insert > code" button016-08-31 at 7.57.37 AM.png
Confucian
Dalystown, Ireland
  • FrontEnds.txt
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Well ...after much messing about trying to use both the Left and Right audio channels of a VB cable to transport 2 sets of data ..to one version of Jaero ...I have drawn the conclusion that Jaero only accepts data on the Left channel ..
The right channel being totally unused ..which is a waste ..
I've monitored the Right Channel and the data is present and ..with headphones on you can hear the data moving Left and right from the two channels ...but Jaero turns a deaf ear to the right channel.
I guess the only option now is to set up even more VB cable lines and use even more instances of Jaero ...each assigned its own cable and each only using the Left audio channel ?
I'll contact Jonti at some point and ask him to confirm my findings..
rgds
VS
