Yeah rightTm have gone down hill imho more bothered about cs boxes the old 6900/1500 was great boxes, get a card as was mentioned in your first post/if you have big pocket get this
ERICSSON RX8200 HD Receiver DVB-S2 MPEG-2 MPEG-4 HD AVC HD SDI OUTPUT BRAND NEW
Just if you do go for another technomate box, leave the "enigma 2" flavours alone. Imho.
Yeah rightI'll have two
i hear you chris, there's 1 or 2 things putting me off,
1 i like to take the sat box into the living room at night if the wife is sleeping, that way i don't disturb her ( believe me she is disturbed enough )
2, i would have to buy a remote control for the pc and that can be a bit of a faff, and if I'm using the pc at the same time as feed hunting, that may cause issues,
its £200 for a pcie card.. not a fortune i know , but still ..
but i might,,
thanks rob
i know, i chose the 5502 cos William said it better suited my LNB ...and it was 2 numbers higher so MUST be better right ?? lol![]()
what hardware and software version you running mate..
well the 5502 is NO good for blind scanning everyone DONT buy one !I am running the Phantom patch sofware of 27th May 2016. The latest Phantom patch for both the TM-5302 and the TM-5502 was released on 27th May 2016.
satweb is OK, but would prefer to find my own feeds, that's the whole point, and blind scanning a range off TP's would not take long (IF the receiver worked ! )@ Rob.
Have you used the Technomate to watch any normal TV, not feeds? If so, is it any good for that purpose?
As I said on another post, you can get information about feeds from sites like Satelliweb and watch whatever might be of interest. I am interested in feeds, but I wouldn't spend the whole day blind scanning 30 satellites just to find something which has not been found already, and might not be of any interest to view. And if you are viewing late at night, as I said before there is not much feed activity happening then anyway.
This experience has put me RIGHT off buying Technomate again.The "two higher numbers" for the TM-5502 do not automatically mean it is a better box for feed hunting. The TM-5502 has a CI slot to accept a CAM that the TM-5302 does not. Other than that, they are almost identical except that the TM-5502 comes in a bigger case. Get a TM-5302 and have done with the messing about.
Put it this way, if I was offered one free box from a choice of a TM-5302 and a TM-5502 I would select the TM-5302 every time. My choice of the TM-5302 is 100% due to the blind scan issue with the TM-5502.
cheers rob
ps i bought it for feedhunting, most of the sat channels are total crap, i have sky for regular tv.
