Confucian
- 1.4m Offset, 1.8m Prime Focus for C Band Aero
- Dalystown, Ireland
had two SDR#'s drop out overnight has anyone any idea what this error message means ?Interesting results. I'm getting random SDR# failures when running three at once, I get the usual unhelpful error message from windows which does seem to point to USB/Driver problem, I will post one next time it happens. It will be interesting to see if you suffer the same issue or not (hopefully) !
Keep up the good work , hope you feel better later .![]()
Problem signature:
Problem Event Name: APPCRASH
Application Name: SDRSharp.exe
Application Version: 1.0.0.1443
Application Timestamp: 56f99246
Fault Module Name: libusb-1.0.dll
Fault Module Version: 1.0.19.10905
Fault Module Timestamp: 539e0d04
Exception Code: c0000005
Exception Offset: 00009954
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 2057
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789"
