is C band worth while ?
rob12770
fac ita
Glasgow
2 X Technomate TM-5302HD, Blade 7000s, triax 95cm STAB HH90, 1 M TM dish TM2300 super motor.
Glasgow
Hi all,
I'm just wondering about C band, I'm interested mainly in feeds, and wondering if C band is worth considering, i would probably need to get a dual c-band ku-band lnb, and figure out DiSEqC switching ( not a clue )
any thought or tips appreciated
cheers Rob :)~
Depends what you want to receive. It's an addictive band for sure... C band is used for feeds just like Ku, though probably not as much. You'll need a bigger dish than 95cm though... 1.2m minimum just to get a taste of what's available.
rob12770
fac ita
Glasgow
Glasgow
Thanks Captain,
I plan on getting a bigger dish anyway, but would the 95cm do just to start ? or would i need to upgrade to pick up anything ? bit of a daft question i guess as you already kind of answered it but thought id ask anyway :)
as to getting a bigger dish, that would mean a new motor also, so i would have to carefully consider my options,
cheers rob
95cm will get you very, very, very limited reception. 40E is strong and potentially some channels on 20E but that's about it. 95cm in C is about the equivalent of a 30cm dish in Ku - smaller than a Sky mini-dish.
rob12770
fac ita
Glasgow
Glasgow
right ok pal, thanks for clearing that up .
cheers rob :)
Archive-8
Would would really need a 1.25cm dish, but for c-band bigger is always best.
I have posted quite a few c band crazyscan's on my 1.25 gibertini, and tbs sat card.
It is do able, but not really worth the extra money if its channels your are after.
Plenty of below lock channels, and a few data channels.
The 1.5 dish can lock and give A watchable picture, on most channels it tunes in. And works quite well with my dr hd d15.
nelson_b
Contributor
Hi all,
cheers Rob :)~
The dual c-band ku-band lnb,s generally have a much reduced k/u performance ... separate l.n.b,s on a medium/ large offset dish is a better way to go ...:)
There are different opinions on this but in my opinion. A starter dish for C-band to receive regional beams would be 180cm. Anything smaller is going to be a disappointment and probably put you off for good. For pan continental beams, global beams, and feeds you need a 3 to 4m dish.
With a 120cm dish it is unlikely you will get reliable reception from more than about 10 transponders across the entire arc.
I would tend to agree with the above, I am wringing the neck of my 1.8 CM as regards set-up accuracy and components used and i don't do too badly at all. There are times when i'm just that 1/2 dB short of a lock on some weaker TP,s that i wish i had a larger relector. Can't grumble otherwise
Ive played with C-band a little, using a 1m dish.
Is it worthwhile? Yes for playing with and spending a lovely summer afternoon tinkering in the sun. I've had about 3 tp's on 20E and a couple of Russian channels round about 52E. As a serious source of extra channels - no.
For feeds - forget it on anything less than about 2m.
Its fun to do but unless you can dedicate a motorised BIG dish dont bother (apart from if you want to spend time in the garden seeing what you can get for the hell of it!)
rob12770
fac ita
Glasgow
Glasgow
Thanks for all the info guys, it gives me much to chew on
looks like il have to go fairly big :)
cheers Rob
cheers Rob
This is a case Rob where SIZE really does matter, you can't get away completely with the saying "It's how you use it" on this one :-lol
rob12770
fac ita
Glasgow
Glasgow
Remember you will need:
planning permission
understanding neighbours or a well hidden location.
If you live in a residential area dont even think about putting a big dish up without the correct bits of paper!
rob12770
fac ita
Glasgow
Glasgow
planning permission
well, i already have lots of fairly big antennas and the neighbours are ok with it :)
2M0LDT Callsign Page
Those masts are nice.
Go for it, just remembering an 8 foot dish (2.4m) is another kettle of dish completely though. Factor in you are going to need a couple of tons of concrete to hold it all firm and getting on for a cubic metre of soil to be dug out for foundations.
You want a decent dish too - not one of the flimsy 200 quid jobs you see advertised - get a decent west coast Scottish gale (Hurricane Bawbag style!)a nd you will be stuffing the petals into a couple of bin bags :D
rob12770
fac ita
Glasgow
Glasgow
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Great read............C-band for me yes, just got that 'different feel'...........tonight for example:-
Ku band......Norwich v Manchester United 39.0ºE 11135 V 30000
C-band...... Real Madrid v Villareal 40.5ºW 3769 L 21600
In the end good result for both the Manchester teams.........bad for us at Real madrid.........¿but still better in C-band? respect-057.GIF
