Advice Needed how to ad sats tm 5302 ??
rob12770
fac ita
2 X Technomate TM-5302HD, Blade 7000s, triax 95cm STAB HH90, 1 M TM dish TM2300 super motor.
Glasgow
have a bit off an issue here ..
looking to add 7 west to my lineup ..so i can add the sat ok, but i use USALS and i cannot see there to add the satellite coordinates even in disecq theres nothing to specify the actual sat coordinates. .. any ideas guys.
On the tm5302 you add the coordinates to the name of the sat
E.g.
7.0w nilesat or it could be 07.00w nilesat.
For the usals to work.
thanks chris, i did but it didn't seem to work, il try it again mate :_
Mod. Note: Moved to TM sub-Forum.
Thanks @Lazarus
@rob12770 I can't help you anymore with usals, as I use the remote on my vbox, to drive the dish.
I don't use anything that is usals.
Or you could use on if @william-1 lists.
And then change the longitude and latitude for your location.
your right enough Chris, i did put the 3.0W in before and that IS as you say, how you set the coordinates, the reason it didn't work as the gardener had lent on my dish i just installed at the front and moved it off.. he has been dealt with in no uncertain terms ..seems to be all ok now thanks..
ps i got a SatLink WS-6908 meter.. which made my life a LOT easier :)
cheers rob
pps meant 3 west In my OP it was a typo.
( i know there's seldom anything there but there was a feed earlier )
cheers rob
Using a meter at the dish does make life less stressful. Got fed up with needing a mate inside, and using our phones to talk to each other.
3.0°W is a good freesat to keep scanning. Loads of Stuff pops up. Then it goes quite for a while.
Happy scanning :-)
