Spiff
- Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
- Mullion Cove Cornwall
We are in the process of installing an SSS 550mm stand off 76mm wall mount.
The image on their webpage showed a fully welded bracket which we had expected.
Speaking to them on the telephone after delivery they now only supply the bolt together version.
Though there are holes for ten rawl bolts and three clamps for the 76mm pole, there are just two fairly small bolts per fixing arm to join to the main bracket.
If you loosen these after the bracket is wall mounted it all goes out of plumb.
I had asked the total width required as there is a restricted space to fit the bracket, they gave us a smaller size than the bracket in fact requires.
He did not sound too sure so I repeated the question, but there was no response that suggested a further check was on order, just a conformation of the size given.
This has caused us no end of problems as I have had to bend the arms in, the pads then did nor sit flat to the wall and skewed when the rawl bolts were tightened up.
All this at the top of a double extension ladder : )
The paint chips off if you have to do a lot of levering and messing about, galvanising would have been much better.
I have to fit a second bracket below this one, there is no restriction on the width where this one will be mounted, but to make the stand off the same I will have to bend the arms in the same amount.
What should have been fairly straight forward has turned into a messy job.
I only wish I could have used the floor stand that came with the Precision Antenna.
Just thought I would have a moan, as I get fed up with the service and quality we are expected to except.
Would it not be a much better world if things were made not for profit but for the good of our fellow men : )
God Bless Regards Allen
