Uploading Files/Pictures ?
4wd
Getting the picture
5 W, 9-13-19-28 E
Ok, it's beginning to look like 49.0.2 is goosed, then.
Was on 49.0.1, this post done from 49.0.2, and 'upload a file' is still normal both in apearance and function. W 8.1 64 bit.
davemurgtroyd
Oxford
Oxford
I think it is a Firefox bug as menu options are also inaccessible on another forum (DS) for me on 49.0.2
Archive-8
I have just tried to upload a couple of photos to another topic, using iPhone, it keeps coming up with an error saying
"the contents of the uploaded image doesn't match the file extension"
Well that slightly knocks the 49.0.2 theory, but it nevertheless seems to be the common link of those of us with the issue.
Sounds like you need to bite the Apple and get a self-igniting Samsung (Other cr*p is available).
davemurgtroyd
Oxford
Oxford
Also identical missing button happening on another forum with similar looking software to this one - AVForums. Is it a forum software issue or Firefox?
Well earlier Posts suggest the bug is not evident when using other Browsi.
So it is most likely an incompatibility between Xenforo and Firefox.
It'll right itself with Firefox's next downgrade update. Possibly!
2cvbloke
Near Pontop Pike, Co. Durham
All's well under Pale Moon 26.5.0 (x64)... :)
That said PM doesn't work with the new-style Google Adsense, annoyingly... :rolleyes:
pontiend
Contibruter
south yorkshire
I have ended up with the update anyway.
Firefox version 49.0.2.The button is still visible and working correctly.Up to now.:)
Edit got the blue Moderator bar now .I don't normally see that.:)
Ah, well. The hypothesis has more or less died!
I shall delete my Forum Cookies and see if that has any effect.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
47.0.1----- all ok.
Moderator message showing.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Not sure why pontiend's post are ending up in the mod queue
pontiend
Contibruter
south yorkshire
Someone is sure to say it is because of the rubbish that I post.:D
Still happening by the way.:)
Only Staff can post in this particular area unmoderated, T.
Still on 49.0.1 invisible here also
Is there a possibly that the Windows version coupled with a specific version of Firefox may be the issue, ie, a double whammy invisibility impact? I am using Windows 7 64 bit with Firefox 49.0.2 and I have the invisible button.
