Advice Needed TBS 5925
blademedia
Sky
HEVC UHD 4K
I have same 5925 card, should it be able to view a feed in the above format?
I think it will, the experienced users will tell us better, first time ive ever used something like this,
Blade.Screenshot is pretty good I used it a long time.
I find that the snipping tool is quicker.Also most of the time you do not have to resize the snips.
To find it click Start, then all programs,Then Accessories.It is half way down the list.
If you use it often like I do right click on it choose 'Pin to task bar'.Works in W7. Don't know about W10. Appoligies if you already know this.Don't want to be telling Granny how to suck eggs.:)
Thanks for the info I will check it out,
Works in Win 10 too.
Thanks I use W10 will look into it
WHATAGOAl1 said:
HEVC UHD 4K
Yes,you can receive and lock UHD channels.
blademedia
Sky
Help please, trying to decode MIS at 12.5W using smart dvb, I presume I need to enable and input id, if so best place to find known codes ?
MCelliotG
Thessaloniki, Greece
The MIS codes are 34,35,36 and 37. Note that you need at least 10.2db signal for decoding these streams.
blademedia
Sky
Thanks new to this what code do I need for suppertennis do I input all 34/35/36/37 here
blademedia
Sky
Ok I see now each mux has different number thanks
MCelliotG
Yes, 33 (I missed that)!
blademedia
Sky
HEVC UHD 4K
Hello, it certainly uses the CPU on my laptop, will need to upgrade if I want to view UHD on it
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
I had an issue with 422, where the cpu was in the high 90s, by changing the video decoder it went down to 35, maybe the same in this instance?
blademedia
Sky
Thanks will try different decoder, uhd uses lots resources not confident, how does your cpu run at on same uhd channel at 4,8e ? and decoder used ?
WHATAGOAL1
Leic
Can not get signal on that number, only watch SiS horses on that satellite and they are on, so don't know why it wont scan.
WHATAGOAL1
Leic
got signal, but no picture, I would think I have the wrong codecs
blademedia
Sky
Try the same channels at 19E see what you get there
WHATAGOAL1
Leic
10995 H
DVB-S2/8PSK
HEVC 22000
it is like 4 or 5 snow clouds moving down the screen
blademedia
Sky
I use this setting what's your cpu running at ?
WHATAGOAL1
Leic
couldnt get it to work with dvbdream, so took a tip from you and tried smartdvb
BINGO
the picture is incredible, and the cpu is a bit jumpy between 60 and 75
blademedia
Sky
BINGO
Great. yes picture is very good, will have to try 19E later was struggling with signal myself at 4.8e. do have a 4k receiver that I hope to link to the card at a later date,
Will report cpu usage from 19e later when tested
