45 West Feeds
daaahhnuh
Vu+ Uno 4K SE
Dreambox 500
TBS-5925
Spaun SMS 5402 NF Multiswitch + Sky Zone 1 Minidish
Triax TD88 + Dark Motor using USALS
Suffolk
Any ideas on this one? Enc in PowerVu. Rare to even see a feed on this bird!
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Did a scan and these two Freqs came in beside the one for Rasd.
pontiend
Contibruter
south yorkshire
Now that I can see 45.0W again.Still looking for a feed..This is tonights scan.Only CCM codings I filter ACM.
TBS6983 100cm Dish.
pontiend
Contibruter
south yorkshire
Iv'e done a scan including ACM coding.Only three CCM tonight.Got another scrambled channel though.
11549V 26096.
TBS6983 100cm Dish.
blademedia
Sky
Earlier i locked a frequency 10---- H 32 apsk, couldn't have been from elsewhere nothing round here, will see if it turns up again
pontiend
Contibruter
south yorkshire
I think that EBSPro tells lies sometimes.I once posted what I thought was 16APSK it turned out to be 8PSK.I think that the best thing to do is is a constellation scan.in crazyscan.Scanning 37.6 just now I will have another look when that has finished.
blademedia
Sky
Thanks new to using cards, have used the scan mentioned, will check in future thanks for the tip
pontiend
Contibruter
south yorkshire
Flysat also says that it is 32APSK.
A scan here says that it is DVBS2/QPSK.
I give in.:)
blademedia
Sky
Could you try with your other card see what that says ?
pontiend
Contibruter
south yorkshire
Sorry for the delay.The 6925 card is in the other computer wasn't set up.The TD88 still cannot see 45 West so swapped the dishes.All that and I get the same result.:)
TBS6925 100cm Dish.
blademedia
Sky
Thanks, process of elimination, I am using the latest smartdvb and easy blind scan atm both give same results 32apsk
pontiend
Contibruter
south yorkshire
I get the same result as you using Easy Blindscan.I am beginning to wonder if I have had a can too many.:D
TBS6925 100cm Dish.
blademedia
Sky
TBS6925 100cm Dish.
You must have had a can two many its showing 32apsk :)
Edit I think ive had a glass of wine two many read your post wrong, glad you've got to the bottom of it :)
pontiend
Contibruter
south yorkshire
Yes it is using Easyblind scan.But crazyscan and EBSPro show it as QPS2.Most odd.:)
Edit it's more than two cans.:D
blademedia
Sky
Not sure what I am doing tbh even without wine, but I put everything in one folder, I cant get EBS pro as you cant pay atm, unless some has a cr----d version they could pm me
When I use easy blind scan it says crazycat and EBS pro
pontiend
Contibruter
south yorkshire
Got two more transponders tonight.Still no feed though.EBSpro has decided that 11549v is 32APSK tonight.The constelation chart still says that it is DVBS2/QPSK.Fun this isn't it.:D
Edit why do I sometimes get grayed out transponders
TBS6983 100 cm Dish.
