Spiff
- Technomate TM-5402HD M3 C1+ Super+
Primesat VBox
2 x Actuators
Precision 1.3m Prime Focus Dish & mount.
InvertoTwin Black Pro C120
Amiko Viper4K
Primesat VBox
2 Actuators
Precision 1.5m Prime Focus Dish & mount
Titanium C1W-PLL C Band
Seven Computers : )
Two Davis Vantage Pro Weather stations
One Waldbeck Weather Station
- Mullion Cove Cornwall
Good evening gentlemen, some more of your most excellent advice it you would be so kind : )
I have a 1.4 m aluminium Triax prime focus dish, which at present has a KU band feed horn.
The LNB when fitted bolts through the bracket ( that is supported by the three arms from the dish ) to the feed horn.
Are C band LNB's made that will mount in a similar way ?
The C band LNB in this eBay add looks to mount with a clamp ?
C1W-PLL lite C-band LNBF Integrated Feedhorn Phase Lock Loop Wideband LNB | eBay
I could be wrong as there are holes that look as if it may mount through the bracket mentioned above.
Is this feed horn going to be for a prime focus dish.
Are C band dishes only made for prime focus dishes.
Thank you for your time : )
God Bless Spiff
God Bless Spiff
