Advice Needed 4LNB Installation And setup
alexjames2320
Yumatu Mx Reader With EXTREME Buropa Dish 1.20cm And 2LNB's One AMIKO LNB SINGLE ECO L-107 0.1DB And One INVERTO LNB SINGLE BLACK PREMIUM
Greece
Hello guys i want to install a system with 4lnb's my dish is 1meter 1.05 last time i mesaured it...i have a diseqc switch 4x1 and now i have already installed 3lnb i have as centre ASTRA 19.2 LNBA for LNBB i have Eutelsat 16.0 And for LNBC i have Hotbird 13.0 i get a really good quality from all and especially astra is 95% signal but now i want to install a new lnb with ASTRA 28.2 i live in greece and i know here i cant have all the channels of the sat but im more interested in some channels like travel channel and tru tv mostly and those with music...i have put the lnb on place i usually get astra 28.2 with my previous system but i doesnt work...my problem is i think the diesqc cause when i plug the 4th lnb it corrupts my signal on some channels on eutelsat 16.0 and i cand get astra with no way but if i remove the 4th lnb and let the others on and use the LNBB to get astra 28.2 i will get the signal i dont know whats really wrong maybe im doing something wrong with the installation so please help me find a way.
alexjames2320
Greece
alexjames2320
Greece
thats my setup right now white LNB is centre astra 19.0 and then is next one eutelsat 16.0 and then hotbird 13.0
Mickha
North West
Can you please post some of the channel details, names, frequencies, etc., that you can get from 28.2E, on your current dish.
Try just using 1 LNB, connected directly to your receiver, to get Astra 2, 28.2E, try the Europe beam channels, like 11264 H 27500.
alexjames2320
Greece
friend i dont want to watch ASTRA 28.2 at single cable i want to do it with multiple lnbs the thing is that is not possible i tried everything and its really far away from the point were astra and eutelsat and hotbird is...
Greece is outside the main service area of 28E nowadays so you may well struggle with even the Europe beam especially if you are in the east of the country. Your best bet is the 2G Europe beam from the coverage maps.
You probably need to slew the dish so as to have 28E at the centre focus, then reaarrange the lnbs so the stronger signals are on the offset lnbs.
Mickha
North West
I understand that, it's just that I'm not certain you have the 4th LNB aligned to Astra 2, 28.2E, and that you might have to re-position your dish, slightly, to get the four satellites you want.
Which is why I would set one LNB up, at a time, to ensure I've peaked the signal, and gotten each satellite.
Check the beam maps, for the Europe beams, as satated by Analoguesat, I would aim your dish more towards Astra 2, 28.2E.
http://www.lyngsat-maps.com/interactive/Astra-2G-Europe-Ku.html
http://www.lyngsat.com/Astra-2E-2F-2G.html
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
When I understand your story without commas correctly, I would say that your diseqc switch does something strange indeed; I think your suspicion could be right.
A33
A33
Which switch are you using?
