- Dec 10, 2004
- 1.2M Channel Master, 1224 motor, VU+ Duo 2
- North West
You can check on dishpointer.com to see if the tower block is actually blocking access to other satellites. Type in your postcode, select 16E from the satellite drop down box, then zoom in on the map to where your dish is located.
You might want to investigate IPTV receivers. These work using the internet and don't require a dish.
