Cable crimps
Archived-1
Persona non grata
uk
Hi, what crimps do I need for these please.
What size cxable is it for, that looks like at least 1.25 core.
This one should do it.
http://www.satelliteandaerialsupplies.com/product/?s=vision-v18-203-crimp-tool-for-f-type-high-quality-ct100-125-167
Archived-1
Persona non grata
uk
Hi rolf the cable is thick stuff CT 167, I will take a look at the link thanks :).
satelliteman
Difficult to tell without measuring the connector, either 165 or 233 coax.
The tool in the link will be ok.
Sent from my SM-N910F using Tapatalk
Archived-1
Persona non grata
uk
Taking a closer look at this its CT 167 PE, and its 1.67 in diameter.
Martin - with the WF/CT/PF series of cables the number part refers to the diameter of the centre conductor in millimetres.
In order to maintain 75ohm impedance the other bits are successively larger in diameter and, reading the table above, that CT167 is 10.5mm diameter. Is the plug supplied with the cable? Otherwise you might need to check to be sure it's right.
Archived-1
Persona non grata
uk
Thanks Paul, the plug and cable do come together, its old stock, it was used for betting offices a fair few years ago, I am missing the inner part of the connector, I will be picking them up sometime this week I will post up once I get it.
Terryl
Custom built PC
Thats some lossy coax, (12 dB at 1 GHz) what are you going to use it for?
Standard RG-6 quad for TV signals is 8 dB at 1 GHz, RG-6 quad for satellite systems is about 11 dB at 3 GHz. (all rated at 100 feet)
Archived-1
Persona non grata
uk
I am going to use it on all my dishes.
Think you'll find that's 12db per 100 metres, 12db per 328 feet.
Terryl
Custom built PC
Ahhh now that if found that spec for that coax on the web, I see that, could not tell from the pic you posted, old eye balls at work again..........Sorry their fault.
Archived-1
Persona non grata
uk
Its £200 a roll it should be good stuff.
The signal loss for the CT167 is commendably low for the frequencies quoted but it worries me that it stops at 1000MHz. It's probably OK at higher frequencies but there's still that little niggle annoying me.
Archived-1
Persona non grata
uk
Its doesn't worry me :), the chap did installs for betting offices for a living and also was into fringe and feed hunting, he tells me you wont get much better coax than this, its got to be better than what I am using and a 50p a mtr who cares :)
LOL, got the same problem here Terry. :)
Terryl
Custom built PC
Archived-1
Persona non grata
uk
That's just it the price, they will be even better stuff out there at a price, this cable I will be using if it wasn't for getting it for £50 for the roll I would not be using it, maybe one run if I had to pay the proper price,
From a hobby point of view its dam good cable and its not broke the bank to put all my runs with it :).
Terryl
Custom built PC
You should see how much it costs for waveguide from the dish, almost like gold plated coax.
Archived-1
Persona non grata
uk
I can imagine Terry, I am using Webro WF 100 atm and its a bag of shi*, I only have to point my camera at the tv and the signal drops 2%, I don't know why some peeps rate this cable because its not what its made out to be :(.
