CCcam 2.1.0 & NDS 2/3 Cards
lovelldr
85cm Gibertini Aluminium Dish
Inverto Silvertech 0.2dB Twin LNB
Super Dark Metal Gear Motor
DM800 HD Box
Eagle Box
East Midlands
Bram1nat0r said:
One question hopefully someone can answer : How exactly does one create the HEX BOXKEY for use in CCcam.cfg ?
Let's say my serialnumber of my Sky box is : 0289123121
Cheers,
B
OK, to get the box key from that serial, remove the first and last digit:
28912312
Then use windows calculator (Start -> Run -> Type "calc" & press enter). Then go to "View" & choose "Scientific". Then convert it to hex by typing the number, and then choosing "Hex" from the options:
1B92AB8
Because 8 digits are needed, add a ZERO in front:
01 B9 2A B8
This should give you your box key...
Let us know if this works, and if you need some testing help, then let me know :)
markformosa
dreambox
mt
Hello, I can't manage to get my CCcam 2.1.0 to read skyIT card via smargo usb reader on ubuntu linux pc... the card works okay when inserted into the dreambox but overheats..
any suggestions? I have tried everything...
PS my SKY UK card is read fine..
Bram1nat0r
DM7000s
Thx lovelldr !
It turned out I correctly calculated my boxkey (just needed confirmation)
In CCcam2.1.0 the card is read, but the entitlements are not listed.
I tried the card in NewCS. In this CAM the entitlements are read. I can even connect a CCcam client to NewCS, but the picture freezes every 5-6 seconds.
Will post here, if I have any updates.
Cheers,
B
alexjuve
DM 500s
bizerte
hi i have a big problem,sky didn't work with me i have the new cccam 2.1.0 i wan to know what's behind thi problem pleassssssssss!!!!
and what i should do to repare this i have DM 500s and all works but sky it presisly sky sport and calcio are not available since 2 weeks sky worked but like all the time with freez)(-red
pleass help freind!!!!!!!
alexjuve
DM 500s
bizerte
just i wan fix sky!!!!
thaks
:-worship
betty1234
dream box dm800 sky 2x lnb
glasgow
hi B16MCC i have the same card as Bram1nat0r
papampi
DM-600 -Ubuntu Desktop server
GEMINI 4.60
CCcam 2.1
24x7 online with ups
IR
B16MCC said:
More from Me. This morning I ran my Sly IT NDS3 card in the smargo using CCcam 2.1.0. My card is a 0002 'K' type.
Early indications are very good. I ran the card very slowly using the following line in CCcam.cfg.
SMARTCARD CLOCK FREQUENCY : /dev/usb/tts/0 3430000
I have yet to monitor CCcam in debug mode via telnet but what I can see so far is good. From inserting the card into the smargo it cleared a channel within a couple of seconds. My local ECM time was steady at 0.175 , so thats good. The temperature of the card was quite normal with no excessive heat to worry about, absolutley no signs of burn, although the test so far has totalled only about 15 minutes.
This test was simply to run the card for my own local use. I will now expand the test to share it and perhaps increase clock speed slowly. I'll report back further findings. At this time I have no need nor interest in trying the card in the internal reader. I would recommend against it for the price of a smargo.
Hi Bro
thanks for the info !
I just get my new Sky Italy white k-type card and as I'm a bit afraid to burn the card i wants to confirm the settings first !
I have DM-800 with latest gemini 4.2 and smargo smartreader +and linux ubuntu server .
which combination is best option fo me and the card :
1- DM-800 and Smargo and CCcam 2.1.1 ( I dont like this setup as dm crashes from time to time )
2- Ubuntu server and Smargo and CCcam 2.1.1
3- whatever you say !
then its that the card is not active yet and i dont have the official receiver ! how do I activate the card !?
I read some where this process :
1- put dm on common interface
2- put dm on a sky channels
3- insert the card
4- telnet and run newcs
5- frm BP run CCcam 2.1.1
6- have a bear and wait
is this ok or i should I just put it in smargo with dm or ubuntu and wait !?
please any who has the experience help me set it up sooner !
thanks
djremmit
Dreambox 8000, 7025,7020,3 x 7000,500. (Dreambox in every room)
Wavefronteer 55 dish with 4 LNB's: 13, 19.2, 23.5 and 28.2.
Switch 17x8
Heidelberg, Germany
I have an irritating issue: With CCCAM and NEWCS I do have a picture, but the entitlements don't get updated... (Blue SKY card)
Any help is welcome
WildBit
-DM800 fixed on 28.2-quad
-DM7020 motorized
-Skystar HD2 motorized
-Cards&Cams&Cas
Ireland
Hi, welcome to the board. You might want to introduce yourself to the rest of the community... I have no direct experience with SlY DE but if it's a card similar to the new white SlY UK card than you will need MGcamd + NewCS . There are many posts on this issue, just follow the thread containing word "0963"
djremmit
Switch 17x8
Heidelberg, Germany
@Wildbit, thanks for the welcome.
The issue I have is with the old S|Y UK card. I did not receive the white one yet.
I have been running Newcamd with NewCS in the past without any problems, but made the move to CCCAM to keep other cards working as well: running S|Y DE without any problem because its Betacrypt, Cana*dig NL on SECA2+ and AR*NA DE via Cryptoworks.
(The Cryptoworks also refuses the updates, but that's less bothersome as S|Y UK: for Crypto I have a Cam to update the card, for S|Y UK I have to set up a seperate dish without diseq, install the original receiver and wait.....)
Thanks,
DJ
btw all my DM's are running Gemini
prenz
Kathrein UFS910, DM500, several ipboxes.
de
This seems to be an issue of NewCS/CCcam - no entitlement updates on my system as well, neither blue nor white card. Run mgcamd as client and entitlements will update.
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
djremmit, Welcome to the fight..
Are you hosting the card in NewCS or direct in CCcam. If its in NewCS, there's no need for it. Use CCcam direct for that card and it should be just fine.
GMAN6
Eagle x2 DB500 & 95cm motorised dish
sussex
I use cccam 2.1.0 on blue and my entitlements are at end of december now it updates consistently unlike the white card.
WildBit
-DM7020 motorized
-Cards&Cams&Cas
Ireland
If you've activated the white card on the same account, your blue card will surely be killed if you allow emms to reach it
Oakey22
Penta 85cm, Quad LND, DM8000,Nabilosat Blackhole v11.
Staffordshire
I have had white card used for about a month now with my blue card in the dreambox, white card still in my sky box. I have EMM's getting through aswell and the entitlements are December now. :)
B16MCC
/var/tuxbox/config
The old card is only killed when the sly box phones home to acknowledge the new white card has been inserted.
Burnham Beech
I would guess most regulars on this forum don't have the phone line connected.
Surely Ѕky will stop send updates to the old blue card at some point?
stvy
DM7020-s
norway
Currently I have my new white card in my $ky hd box. It works. It upgraded to the new card no probs. NB I dont have the phone line connected and I dont have too.. My subscription is an "unsubsidised" and I have no obligation to have the telephone line connected.
I left my old blue card in the dm800 and it continues to get updates. Right now I am good upto december.
I am just hoping to keep on going until there is a nice and easy white card solution that takes care of the updates etc... I currently use cccam.
thanks,
sTvy
WildBit
-DM7020 motorized
-Cards&Cams&Cas
Ireland
yup, that explains it... the tech had to get a call back to get the white card activated for some reason
djremmit
Switch 17x8
Heidelberg, Germany
Yes, everything works perfect after I removed newcs!
