CCcam 2.1.0 & NDS 2/3 Cards
peque
DM800
DM7000
Mythtv + 3xHVR4000
DK
Hey there,
I've succesfully followed the most of the forum here and managed to get my DM800 up and running with a Via***t nds card.
But unfortunably the HD channels aren't working.
Using Gemini 4,5 and CCcam 2.1.3 and got the normal channels running.
Here's my addings to CCcam.cfg
SERIAL READER : /dev/usb/tts/0 smartreader+
SMARTCARD CLOCK FREQUENCY: /dev/usb/tts/0 6860002
Which I get a picture and a good result with - But not the HD channels.
When starting CCcam - It looks good, but it's not possible to get HD working???
Log Removed.
Does anyone have the rigth settings or isn't it possible to makje HD run yet.
Many have shown pictures on the net - but not the solution.
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
Judging by the config sample you have quoted you have not specified a boxkey, I've no idea whether this card needs one or not but as the other popular NDS3 card currently in use DO require one, I'd be very tempted to generate one and add it to the config.
peque
DM800
DM7000
Mythtv + 3xHVR4000
DK
As far as I can tell - The boxid isn't nessecary as I have 2 different cards to try with - and both are just running fine on the normal channels - but no HDchannels - eventhough there's been several postings about succes with this.
So I haven't tried it - but doubt the problem are there !
as they are running fine on normal channels are running fine and CCcam are making the BoxID itself:
17:53:16.069 CCcam: /dev/usb/tts/0 configured clock frequency: 6860002 Hz
17:53:16.353 CCcam: nds card found
17:53:16.983 CCcam: nds: using boxkey XXXXXX
B16MCC
/var/tuxbox/config
You miss the point. The premium / HD channels can sometimes require the boxkey. The boxkey CCcam creates is random and is not correct. For the time it takes to create and try a boxkey , just do it then we know for sure if its needed or not. Also I would suggest using CCcam 2.1.3.
peque
DM800
DM7000
Mythtv + 3xHVR4000
DK
Well It doesn't help.
I added the boxkey in CCcam.cfg - buit still making the same "random" boxID as before adding it ? So nope didn't help and no pictures on HD channels
shumifan50
2xDM7025(DVB-S tuner), DM600SPVR, DM800S, DM500S HD, Triax 90cm with MultiBracket 4 sats.
Europe
I had the same problem and had to specify the freq as well, then it cleared.
peque
DM800
DM7000
Mythtv + 3xHVR4000
DK
Well My settings are these:
SMARTCARD CLOCK FREQUENCY: /dev/usb/tts/0 6360000
BOXKEY: /dev/sci0 80 BF XX XX
Should it be a different frekvens - have tried many diffferents setups here
peque
DM800
DM7000
Mythtv + 3xHVR4000
DK
Well - I've added the BoxID - But when running CCcam - uit still makes a random Boxkey - and NOT the one I've added ?
The line is:
But CCcam-2.1.3 -d shows this:
08:29:14.558 CCcam: nds card found
08:29:15.580 CCcam: nds: using boxkey 0CDFE72A
In CCcam it set with these params as shown above
Is this Correct or is there another problem somewhere ?
B16MCC
/var/tuxbox/config
peque,
I see you have a smargo setup , and you've set quite a high clock speed and one that is not supported (6.36mhz).
Although I think the smargo will just switch to the nearest supported setting. (6.00 or 6.86 ).
However more importantly the boxkey you have entered you have assigned to the internal reader and not the smargo.
Where is the card , is it in the internal or the smargo ?
peque
DM800
DM7000
Mythtv + 3xHVR4000
DK
Its a Smargo - I don't have any cards in the internal reader - only Smargo!
peque
DM800
DM7000
Mythtv + 3xHVR4000
DK
Well - I've changed to path from BoxID to:
BOXKEY : /dev/usb/tts/0 XX XX XX XX
And it looks like it's working - Allthough I cannot check the TV rigth now - But can see the ID of the Boxkey changed
B16MCC
/var/tuxbox/config
OK, so now you have assigned the boxkey to the correct reader where the card is, it should be fine.
peque
DM800
DM7000
Mythtv + 3xHVR4000
DK
But now I'm getting this error and still no picture:
10:54:54.736 CCcam: local emm -> card /dev/usb/tts/0 0x90f(0x000)
10:54:54.758 CCcam: emm already handled (found in cache)
10:54:54.953 CCcam: nds: invalid reply 9080 on EMM:
10:54:54.953 CCcam: 0000: 82 00 45 81 02 00 41 90 - 3F 42 01 9D F8 FE 5C 86   ..E...A. - ?B....\.
10:54:54.953 CCcam: 0010: 47 70 CF E7 70 39 73 59 - AA 39 4B 38 45 15 43 1E   Gp..p9sY - .9K8E.C.
10:54:54.953 CCcam: 0020: ED 86 D7 86 5B 59 C1 63 - B4 49 88 71 65 35 76 71   ....[Y.c - .I.qe5vq
10:54:54.954 CCcam: 0030: 1B D3 4C 34 54 E0 1E 57 - FC 6B 11 63 16 E6 17 27   ..L4T..W - .k.c...'
10:54:54.954 CCcam: 0040: D7 64 70 FB 94 AF 9E C5 -                           .dp..... -
10:54:54.954 CCcam: local emm <- card /dev/usb/tts/0 error
10:54:59.647 CCcam: local ecm -> card /dev/usb/tts/0 0x90f(0x000) sid 0x640
10:55:00.073 CCcam: local ecm <- card /dev/usb/tts/0 error
So what does this mean - Too much clock frequenzes or ???
jakkoi
dreambox800 hd
arnhem
hi
I have a question.....
I got a new sly uk I have no original box.....I put the card in my db800 using CCcam 2.1.3 its in my box for a week now and still not working......
when I telnet I got this info.......what is wrong or what do I wrong.......I have no boxkey and I hope someone can help me cuz Its a lot money for something is not working......
23:42:42.113 CCcam: ============================================================ ==========
23:42:42.118 CCcam: starting CCcam 2.1.3 compiled on Nov 14 2009@00:37:55
23:42:42.118 CCcam: ============================================================ ==========
23:42:42.119 CCcam: online using nodeId [fieldset=Admin]Node ID removed for your protection[/fieldset]
23:42:42.185 CCcam: dvb api3 detected
23:42:42.189 CCcam: DM800 detected
23:42:42.189 CCcam: create 8 cam device(s)
23:42:42.365 CCcam: nds card found(new type)
23:42:46.040 CCcam: card init fail
23:42:46.224 CCcam: nds card found(new type)
23:42:46.347 CCcam: readKeyfile: cannot open /var/keys/SoftCam.Key or not found
23:42:46.348 CCcam: readKeyfile: cannot open /var/keys/AutoRoll.Key or not found
23:42:46.349 CCcam: static cw not found or bad
23:42:46.350 CCcam: parsed 0 entries from /var/etc/CCcam.prio
23:42:46.351 CCcam: readProviderfile: cannot open /var/etc/CCcam.providers or no t found
23:42:46.352 CCcam: readChannelList: cannot open /var/etc/CCcam.channelinfo or n ot found
23:42:46.353 CCcam: server started on port 12775
23:42:46.356 CCcam: no working cam devices, no need to start pmthandler
bite
Superkomanda
0.8W; 4.8E; 13E (90cm),
19.2E; 28.2E; 36E (110cm),
DM800SE, DM600
Riga, Latvia
Hello there. I have Viasat Baltic official card which I would love to "get working" on my DM600's internal reader.
I have the BoxKey of the card also. It's NDS2 card.
So, what settings (maybe you can post the hole thing, I just will replace it with my boxkey) should I use on CCcam.cfg? And, how can I set to share this card on my local home network? Thanks! :)
B16MCC
--- DM 8000 HD PVR &amp; DM 800 HD ---
Motek SG2100 &amp; Triax 80cm Dual LNB
---- Sly HD Full &amp; 24&quot; Apple iMAC ----
/var/tuxbox/config
Not sure an NDS2 card will need a boxkey , but I may be wrong. I have no experience of this card. Have you tried it at all ?
The Dreambox Config Creator may help you. You'll find it in the Dreambox General section.
bite
Superkomanda
DM800SE, DM600
Riga, Latvia
So, made it:
SERVER LISTEN PORT : 12000
SMARTCARD CLOCK FREQUENCY : /dev/sci0 3430000
BOXKEY : /dev/sci0 XX XX XX XX
F: dainis otrsdrims 1 0 1 { 0:0:1 }
But it's not working. Using DM600's Internal Reader.
SERIAL READER : /dev/sci0
This isn't working either... :(
peque
DM800
DM7000
Mythtv + 3xHVR4000
DK
Hey Bite.
Install CCcam2.1.4 and put the card in the internal reader.
Normalky you don't have to set anything there - unless the cardreader defination and thats it!
I have Viasat Scandinavia running like that
bite
Superkomanda
DM800SE, DM600
Riga, Latvia
With cardreader defination you meen this?
B16MCC
/var/tuxbox/config
bite, that line will never work. Your internal reader is not a Serial reader. That line is wrong and does not make sense. Do not use it !
