ITV HD settings on various (mainly non Freesat) HD boxes
Kins
TOPFIELD HD PVR + ANALOGE
+SKY FREE TO AIR
NORTH WALES
Has anyone had any success with a Topfield PF7710
Kins
Kins
If you had read the first post properly you would have found the answer.
machno
32 " LG with built in 160 g recorder and digital terestrial Tv with twin tuner - 85cm Penta dish
Humax HD 2000 ci and
Nanoxx hd 9500 receivers - all linked to
my computer and 7 digital speakers with subwoofer
rotherham
microcircuit said:
Can anyone help with details on how to setup a NanoXX 9500 HD to Receive ITV HD
I have ITV HD on the Nanoxx 9500 HD with these settings
Eurobird 1
transponder 22/43
fec DVBS
Horizontal
Sid =0
Video = 3401
Audio = 3402
PCR = 2326
MACHNO
Intersync
SIM2 Proj,Humax2000,
yamaha2600,Skyboxes
Sussex
Is ITV HD ever likely to be available on a Sky Digibox -- do you think ?
machno
rotherham
Don't have a sky box so i don't know.
My nanoxx works fine with both bbc-hd and itv-hd but i had problems sorting out the sound in the beginning.ok now
machno
thornlv
mvision hd200
uk
ok on the Mvision HD200 (and combo), just add these params into transponder edit.
'Menu/Satellite Search'....select Astra 2A-D/red button (TP Edit)/select transponder 11428/blue button (PID add)....fill in the values:-
Service ID = 2326
Video PID = 3401
Audio PID = 3402
PCR PID = 2326
CAS = On
HD Video = On
AC3 Audio = On
Then, remote control 'OK' on the line 'PID add'.
Exit.
These values work for myself.
Other working values have been entered as :-
Service ID = 0510
Video PID = 3401
Audio PID = 3402
PCR PID = 2326
CAS = On
HD Video = On
AC3 Audio = On
Exit.
Confirm when there IS a broadcast taking place as ITV does not always display the 'not available right now' logo, and you get various to no signal or scrampled channel.
kuttan71
HUMAX PVR 8100 CI
FORTECSTAR PASSION HD+
80CM FIXED SINGLE LNB DISH
60CM FIXED DISH
MATRIX RELOADED CAM
IRDETO MPEG4 CAM
VIACESS RED CAM
CUMBRIA
i bought a fortecstar passion HD +. ITV HD is tuned in, but i get a screen from ITV saying ?ITV HD THIS SERVICE IS CURRENTLY UNAVAILABLE
Also when i plug in an external USB 2.5'' HDD, it remains on even if the box is left on standby. Is this normal?
many thanks in advance!
Yes - ITV HD only transmits a couple of hours a week!
Kins
+SKY FREE TO AIR
NORTH WALES
ITV hd onTOPFEILD 7710 found access on EUROBIRD 1
27500K
11428M
HOPE THIS HELPS
KINS
27500K
11428M
HOPE THIS HELPS
KINS
Does it scan it automatically and work immediately and what is it called after a scan.
Sonnenkind
AB IP BOX9000HD
Isle of Wight
Any help with an AB IP box 9000hd?
Just answered you on the other post Mike, as your box is similar to the CubeRevo.:)
SmilingBoy
Triax TDA-88 - Triax 4x Multifeed Holder - 4x Alps Quad pointed to 13.0°E, 19.2°E, 23.5°E, 28.2°E, 3x Spaun DiSEqC 4/1 Switch, Vantage HD 8000S, Vantage X211S CI USB
Brussels
Vantage 8000S HD works, too.
surreyblue
Humax Hdci 2000
Diseq motor
80 cm dish
England
developers said:
I've got it working on the Humax HDCI 2000 now after a lot of messing. http://www.satellites.co.uk/satellite/freesat/124971-itv-hd-humax-hdci-2000-a.html#post743141 shows the method and a copy of my channel list from the formula program for Humax.
Why oh why did ITV need to make it so difficult, I thought the freesat licence was to be free to air not "free" to those who shelled out cash to a select few retailers/manufacturers. It doesn't seem any more free than the Sly offering unless it's open to us all.
Jem
Thanks for zip file Jem, have downloaded to Humax and Itv HD channel ok!
My problem is using motorised dish and have to re-load my settings when viewing other satelites.
Have tried to copy and paste Itv hd settings, but when pasted the transponder data filed is blank.
Have also copied BBC HD channel and ammended accordingly, but just shows blank screen with no HD logo.
Any idea why I cannot copy to my listings file or even copy to new file?
Thanks in advance
developers
www.development.plus.com
Vu+ Solo 4k PVR using Enigma2, Motorised Triax 1.1m, fixed Orbital 80cm dish with 3 LNB 13e, 19.2e and 28.5e 4/1 way diseqc Cas 3+ Diablo 2.3 & TRex 4.6 Rover SDM2 & Satlook HD
Cheshire.
surreyblue
Humax Hdci 2000
Diseq motor
80 cm dish
England
Have downloaded file, and now works ok!
Also picking up satelites that I was unable to before with my search!
Have some editng of channels to do now.....
Thanks again Jem for your help.....keep up the good work!
Cheers
bograt
fortec star innovation hd with 90cm motorised dish
oldham uk
ive just bought a fortec-star innovation hd full kit but 28.5 is not listed in satalites and i cant add it manualy from what i can see is itv hd on any other sat.....sorry if this is a dumb question but i am only 3 weeks into sat tv.
satelliteman
You can add the transponder to Astra2 list : info ITV HD 11.428h, 27500 2/3
bograt
oldham uk
i loaded that tp but the search brought up nothing even though it has good signal,i cant find itv hd listed on lyngsat for astra either
