Astra 2E at 28.2E: General Discussion Part 2
davidcmadrid
40cm offset 19e, 1.5m 28e 1.2 M motor vu+
Madrid Spain
Current orbit is slightly elliptical so 2E has a daily cycle wandering between 28.30 and 28.42.
I realigned my 1.8m dish yesterday. Graph attached. Look at around 17:30. Picked up lots of signal on 2E for almost no trade-off on 2F.
Very interesting. I imagine you are now focussed between the two sattelites ? 1 - 1.5db gain is i think a jump in dish size e.g 1.2 - 1.5 ?
I used 10818V as the guide. Plenty of signal on 2F so I concentrated on 2E and it doesn't seem to have affected 2F at all. If anything it has improved a tad. If I map the current level for the last 24 hours against the daily trend since switch-on I get this.
It's not like you to speculate, solly: We normally rely upon you for the Facts! :D
how need to good swiming :) the pool
Salva
DM800S and Tecatel 1.2 Offset
Gandía (SPAIN)
Interesting .... being in the same area as you and having a 1,2 offset makes me thinking on readjusting the dish
can you confirm if the gain is noticeable across the day ?
M60
Northern England
You can see it in the graph in post #502. That is today's SNR compared to SNR since switch-on. So, for example, baseline is signal reading since Thursday at 6am, split into 10 minute sessions on all QPSK transponders. Then today's reading is superimposed on that baseline. So anything above 0dB is better than an "average" day. Right now I'm about 0.5dB up on 2E across the whole day.
davidcmadrid
Madrid Spain
I should have thought to filter out the weather differences the most obvious measure is the change when you adjusted the antenna ?
Bengt
1,8m PF dish (situated on balcony),Invacom Quad or Inverto LNB (it varies), Sky Digibox, Humax Foxsat HD receiver, TBS8922 card.
Trelleborg (swedish south coast)
So 12441V is also active, is this also on 2A South beam do we think?
Hi
I can't tell. I'm having a hard time distinguishing 2A South from 2E PE at my location.
Regards,
Bengt
Pride Of Cucamonga
Valencia (city)
That's not going to happen. Positions are registered with ITU and you need to have a satellite in that slot to maintain rights the position.
Eutelsat will not have any satellites at 28.5 but they're not going to lose the slot. I;m sure there's some leeway.
FRINGE
Adeje in Tenerife
laminas 2.7 offset
laminas feed horn
Invacom quad LNB
Humax foxsat PVR
Tenerife
Center of box ,window center is 28.35. and will be there at least 25.02.14..ses.com
What difference, if any, would this make to fringe reception?
BLUEPLATINUM
Maspalomas, Gran Canaria
what is mean centerbox ?
It relates to the exact position they intend to maintain the satellite within its permitted space. The relevance of the data is that it proves they have no intention to relocate the satellite during the period shown.
Sent from my GT-I9205 using Tapatalk
Schroeder
2.2m Pasat prime focus with Invacom c120 quad LNB, PACE DS430N, Ferguson Ariva 200, Humax Foxsat HDR
Albatera, Alicante, Spain
SUBJECT: ELEVEN PARAMETER EPHEMERIS FOR Astra-1N/ 28.20 DEG. E
YEAR MONTH DAY HOUR MINUTE SECOND
2014 02 12 23 00 00
THE EPHEMERIS VALUES ARE:
LM0 LM1 LM2
DEG. E DEG/DAY DEG/DAY/DAY
27.9933 -0.5787 0.000834
LONC LONC1 LONS LONS1
DEG. E DEG/DAY DEG. E DEG/DAY
-0.0066 0.0012 -0.0039 0.0005
LATC LATC1 LATS LATS1
DEG. N DEG/DAY DEG. N DEG/DAY
0.0260 0.0015 -0.0269 0.0008
THE NOMINAL ORBITAL LOCATION FOR THIS SATELLITE IS 28.20 DEG. E
THE PREDICTED SATELLITE LONGITUDE AND LATITUDE AT 170 HOURS AFTER
EPOCH ARE 23.9374 DEG. E AND 0.0192 DEG. N
Looks like 1N is on it's way to 19.2E
Mod. Note
As advertised, and as further advised by Schroeder above 1N is most definitely moving Westwards
Member dmaavrigdo provides further evidence here
Can we please continue substantive discussion of 1N in the linked Topic alone, now that she no longer has relevance to what will go on at 28E?
