Astra 1N moving to 19.2E
It's only supposition, but owing to the need to release 2C for back-up duty at 28E, and it's condition, the latter is likely to be offloaded as first priority.
Looking at what has happened with other recent migrations, it seems probable this will start within a couple of days upon completion of integrity tests on 1N.
After 2C is emptied, then perhaps 1L will migrate.
1L will remain on station as back-up.
Retired Mod
www.timo.me.uk
You'll hear me shout if they do something since 90% of the channels I enjoy from 19E are on 2C and 1L. I'm making most of them for the final few days??... :(
what about astra 1l back up to 1n
who it take tp 1kr or 1m ?
i think you can get signal from 1n
maybe 1.8m or 2.4m
will be signal
Retired Mod
www.timo.me.uk
maybe 1.8m or 2.4m
will be signal
Maybe, but I can only fit an 80cm on my balcony, which is currently giving me about 14dB signal on 2C, 12dB on 1L/1M and 11dB on 1KR. It'll be interesting to see what happens.
Retired Mod
www.timo.me.uk
I'm sure Astra 1M will continue as normal. It was only launched in 2008.
Not sure why 1L is to be cleared and not 1KR, if that is the case. Maybe it is something to do with the spot beam capability of 1KR or the Ka Band capability of 1L/1N that is influencing the decisions?
1kr not take high band only low band
it interesting
1l after move to 1n same tp will be mprt need to migration order astra to 1l ?
Pride Of Cucamonga
Valencia (city)
As 1KR was a replacement for the failed 1K, where did this satellite come from? Was it originally intended to be 1L?
masybe low band from canal plus spain it posible to move to 1l
Tururu
Assembled with recycled parts
Recycled as the owner.
Imposible ver las balizas Astra1N/Unable to see the beacons Astra1N.
M:W
Localizadas otras balizas de.???? mas tarde subo fotos.
Localized other beacons.??? upload photos later.
10943H
11195H
11214V
11702V
Retired Mod
www.timo.me.uk
It was launched 4 years after 1K was lost, so it might have been built to order? How long does it take to build a new satellite?
astra 1kr
not change of zdf hd
T.Tanilsoo
Satellite: 78 cm offset, tuner Xoro HRS-8500 Positions: 19.2°E and 13.0°E.
Computer: Samsung N220 Plus laptop, 1 GB RAM, Lubuntu 14.10 64 bit;
MicroLink desktop computer, Celeron 2000, 1 GB RAM; Lubuntu 14.04
Laguja, Estonia
Signals still strong. Just worked on the dish to make sure it was as perfectly aligned to 19.2°E as possible. Apparently I had quite a bit of room for improvement. Also was able to tweak the 13.0°E LNB to work in the new corrected position and was able to improve signals on both. Now we can wait and hope. I guess there is chance that I may still receive something over here(58.16°N 26.45°E) despite 78 cm offset, but just less weather reserve.
adonis1
Tururu
Balizas localizadas en 19.2ºEste.
Una que no es facil ver es 11195H al ser tapada parcialmente por el tp vertical 11186V y sus probemas.
Beacons located at 19.2ºEast.
One that is not easy to see is 11195H to be partially obscured by the vertical tp 11186V and probem.
i see 11185v
i got signal on 2c
very low 7.6 db
Tururu
Solo desear suerte a todos con el cambio de satelite y que mejoren los niveles, tanto por el norte como por el este.
Suerte Timo_W2s y Solly.;)
PD: Buena pesca para todos en cualquier momento.
Just wish luck to all the satellite change and improve levels by both the north and the east.
Luck Timo_W2s and Solly. ;)
PS: Good fishing for everyone at any time.
signal will be change mid this week
It was built to order - the construction was authorised not long after 1K went swimming with the fishes in the Atlantic. A different coverage design though - 1K had two none overlapping spots
Pride Of Cucamonga
Valencia (city)
As I understand it, the frequency reuse spots on 1K spots were originally intended to separately cover UK and eastern Europe. When 28,2 was chosen for UK the western spot beam was switched to cover Iberia. I guess once 1KR was commissioned there was less capacity demand as 28.2 was firmly established
