bargain second hand big dishes for sale
ABARKIE
Vu Duo, ET9000, DM800se, TM5402, Sat BG, Viasat Latvia, JSC
Triax 1.1m, 43cm Motorised.
Archived: TM600, Eagle, Topfield 5000,TM6900
Find me near J15 M6
Looks like a few on Ebay at the moment
120cm CD Tronix 111389415856
2.4M Prime Focus in Spain 281364707350
1.2 Channel master not working after a paint job 301223124473
1.2 Channel Master in France 261510099169
90cm Channel master 251567221036
Must have used that special stealth paint that makes it invisible to signals, probably got the paint from Area 51.
CROSSBONES
S.Wales
Not surprising without the lnb:rolleyes:
Bet that CDTronix 1.2m dish outperforms the 2.4m flappy thing...
aceb
Prof Tuner 7301 /
Sussex
Hey Paul, have you ever tested that 2.4m in C?
joddle
Massanassa, Valencia, Spain
Had one that once looked identical to that - looked very different after a gale though - was then almost half the size !!!! In Valencia it managed to get a bit more signal than my 1.2 PF - but nothing like the fixed Pasat I have now. Hours and hours of fine tweeking were all wasted as it was so floppy the slightest wind changed everything - however it did teach me a lot about focus, skew, and how to set up an LNB !!!
aceb
Prof Tuner 7301 /
Sussex
No, I've watched a few come up on Fleabay but idiots pay seriously stupid money for them thinking they will work well on Ku, think the last one went for over £300!! C band of course is much more forgiving so given enough patience and some strengthening mods I'm sure one would work fine, how well I don't know but I'm not paying more than about 50 quid to find out.
mariust5
Cristor Atlas 100HD , motorised 1.1 Triax on Stab H-H
hastings , uk
1.2 CM Huddersfield 171367534782
ABARKIE
Find me near J15 M6
1.2M Channel Master in Colchester
161351428605
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
Heavy duty H to H 36v motor with cm mtg plate, i know its not a dish but thought it worth a mention
Eb*y: 321449067688
Interesting motor... Anyone feel like test driving it? I have a 1m Channel Master dish which would be perfect for this...
RimaNTSS
Some SAT-related hardware.
N-E from Riga
I think I have exactly the same motor. It is written Maximum load 1200 KG-CM, do not sure what it means but person I took motor from said he had 1,4m antenna on it without any difficulties. P1430062 (Large).JPG P1430063 (Large).JPG
Rimant, have you tried it personally? Who is it made by?
RimaNTSS
N-E from Riga
I just got it day before yesterday, did not try it yet. Not sure about who made it. One friend of mine guessed it is one of Jaeger light models.
Hm, does it look sturdy enough for something like a 1m Channel Master dish as I want that one in as high a spot as possible for maximum arc coverage?
I may get it just to have it as a 'spare' in case the 1224 ever dies...
RimaNTSS
N-E from Riga
Firstly- 1224 never dies, and secondly, if it dies, you work little bit on it and it works again, I mean, like new.
Seems it is sturdy enough to hold up to 1,2-1,4m dish. I have plan to install 1,4m plastic dish on this motor soon, will tell ya how it worked.
ABARKIE
Find me near J15 M6
Channel Master 1.2M in Burnley
231277595749 Ebay
