NHK World HD transmission problems 28E
Every so often Im seeing digital smearing on the picture (11223V). Its the same sort of effect you get on a weak signal, although there seems to be plenty of signal.
2 receivers - the Duo & a Humax HD in the bedroom.
Also affects RT HD on the same frequency
Anyone else confirm this?
Will check ...........................
Perfect reception, Humax HDR and Skybox F3, two different dishes.
Some sort of local interference?
Edit: Whoa, not so - watched a little longer and the effect does indeed show, but only on the Humax HDR/Toy Dish combo.
Still seems fine on F3/A different Toy Dish
Weird.
Still the same, streaky flashes of pixellation towards the bottom of the screen on one combo, but not the other.
I can offer no explanation.
sonnetpete
wordpress.com
Normandy, France
Checked with the motorised dish and Dr.HD...nothing wrong that I can see...though it's 7.9dB compared to BBC News HD at 11.1dB
Jimmy H
Leek, Staffs
LG43UH661V with region 2 sky dish
Leek, Staffs
I'm getting it too, both receivers LG integral and Humax HD same Sky region 2 dish quad LNB.
Could be the downlink before the European bounce.
BlindFaith
TBS 5925
Perfect picture both on a PC and a Vantage STB.
Doesn't show on the Promax either.
BlindFaith
TBS 5925
If you can see these artefacts on NHK, RT HD is probably also affected. Both seem to use the same type of encoder. BBC HD shows slightly different parameters.
davemurgtroyd
Oxford
Oxford
I'm also getting streaking and pixellation at different places all over the screen at different times on both NHK World HD and RT HD - Sky DRX890 on zone 2 dish
pontiend
Contibruter
south yorkshire
It seems to be alright here on both dishes.
TBS 6925 100 cm dish.
Alien2 TD88.
SWMBO has reported it on our Sky 2TB box as well now. Must be a transmission problem. I'll message NHK via their fb page
bim
lat 45.3301 lon 14.1822
humax foxsat Thomson Tsr200 Pace 3100 Black pro quad dvbs2 80 and 100cm dishes
croatia Lat 45.3301 Lon 14.1822
we were geting that last week but i assumed it was a critter on the dish or lnb obviously it wasn't.
humaxfoxsat hd 1 mte dish
BlindFaith
TBS 5925
..seems more a receiver problem ;)
pontiend
Contibruter
south yorkshire
Seems to be a decent signal here.
Two diferent time scans with EBScan.
TBS6925 100cm Dish.
BlindFaith
TBS 5925
Multiple receivers of different types in different locations?
Different types? You mean different brandings of the same product ;)
Different location? Sat is broadcast. All replies report SNR > threshold for QEF. :)
Sky box, Vu+ Duo pos & Humax HD all showing similar artifacts here at different times of day. Theres no new sources of interference in the vicinity, (a very quiet valley with hills shielding us in 3 directions, almost no neighbours). No changes at all inside our house. The dish has clear los onto 28E, and the lnb is reasonable new.
28E Astra 2 channels seem to be unaffected.
BlindFaith
TBS 5925
If there are transmission errors due to any kind of interference, you should see them with an analyser like TSReader or TransEdit.
