NHK World HD transmission problems 28E
Duo not so shite after all then?
Its still a pile of crap - and will probably be withdrawn in the not too distant future as Im fed up of it.
The only thing its got in its favour atm is its ability to play old TOTP mp4s Ive downloaded off the net onto its hard drive. :D
Retired Mod
www.timo.me.uk
I've yet to spot this problem on a DRX890 or DrHD F15. How often are the disturbances shown at the moment?
bim
lat 45.3301 lon 14.1822
humax foxsat Thomson Tsr200 Pace 3100 Black pro quad dvbs2 80 and 100cm dishes
croatia Lat 45.3301 Lon 14.1822
Still getting it here but it can be intermitant. Prolonged periods, then prolonged clear spells. Smearing across the bottom half of the screen. Not seen anything like it before. The signal strength and quality is still the same if not a bit higher.
BlindFaith
TBS 5925
Either you can or you can't see the artifacts depending on you receiver or codec.
Whatever the problem was it seems to have been cured - the transmission is back to normal now.
bim
All back to normal here too. excitement over
I've never watched it before this episode!
Probably shan't ever again.
bim
Don't have much option here, since the move we haven't got a great channel selection. I hate taggart but had to watch it last night on true drama!! Good job I've got the full set of David Attenborough dvd's and who can remember Out of Town with Jack Hargreaves, got them too!
