express am6 53e
as soon proton will be start prepare launch astra 2g :)
next launch
"Express-AM6" into its target orbit
22.10.2014 4:35
October 22, 2014 at 4 o'clock and 31 minutes Moscow time telecommunications spacecraft (SC) "Express-AM6" cleanly separated from the upper stage (R:cool: "Breeze-M" on the target orbit.
Start a space rocket (RCN) "Proton-M" was carried out calculations of rocket-space industry Russia October 21, 2014 in 19 hours 09 minutes Moscow time from launch pad 81 Baikonur cosmodrome.
The target orbit satellite "Express-AM6" was derived upper stage "Breeze-M".
"Express-AM6" commissioned by the Federal State Unitary Enterprise "Russian Satellite Communications" platform-based heavy class "Express 2000" and is designed to provide a wide range of communications and broadcasting services on the territory of Russia. Active lifetime of the spacecraft is 15 years, and the payload includes 11 antennas, transponder 72 C-, Ku-, Ka- and L-band frequencies.
Rocket "Proton" and the upper stage "Briz-M" developed and commercially produced FSUE "State Research and Production Space Center of MV Khrunichev. " Upgraded "Proton-M", equipped with the upper stage "Breeze-M", is able to deliver to geosynchronous transfer orbit a payload of more than 6 tons.
This is the sixth in 2014 with the launch of a space rocket "Proton", and 399 th in the history of its use.
Besides the information of @solly's,about this satellite and its launch,can be read here
adonis1
It is expected that in the I quarter of 2015 after the completion of flight tests and checks all the systems on board the satellite "Express-AM6" will be put into operation at the orbital position 53 ° East.
http://www.rscc.ru/press_club/releases/1677.html
it mean will be service after January 2015 ?
it take long time
adonis1
adonis1
After work on the preparation of engines correction satellite will continue to move through its own electric propulsion system.
It is planned that the "Express-AM6" reaches the desired orbital position at the beginning of 2015.
For reference:
First final ascent spacecraft technology through its own electric propulsion system was used by "ISS" under the "Express-AM5." This technology allows you to place in orbit satellites with a mass greater than the energy capabilities of the launch vehicle.
http://www.iss-reshetnev.ru/?cid=news&nid=1815
that's why "Express-AM6" needs so long time, to reach the desired orbital position
tempo
47.5N, 42.2E / Russia
There is an info on Russian space forum that current transfer orbit isn't precise (differencies in apogee and elevation), so small part of xenon ("fuel" for correction engines) could be used for orbit correction. Anyway the situation is not critical.
Electric propulsion system of Express-AM6 used only for slow moving (about 3 monthes) from transfer to geostationary orbit. It has low power and can't be used for orbit correction purposes.
it be large transponder 4 band to be tested
any know position iot signal ?
Ekspress 1373.20 min 31307 x 37784 km x 0.7 deg
Briz 1512.40 min 34984 x 39549 km x 1.0 deg
under orbit
adonis1
The spacecraft "Express-AM6" scheduled to be operational July 1, 2015 .
rscc.ru
That's a lot of testing!
satellite still under orbit
tempo
Express-AM6 is at around 54°E now, will be stabilized at 53°E within one week for IOT.
When compared to Express AM22 that has 3 beams we can pick up in Europe:-
The other European beam is much tighter from AM-6 & the steerable beam is the same on AM6 as AM22 focused over the part of Middle East & Pakistan.
any know date replace ?
tempo
There is an info that IOT will be at 51°E, the same shows tracking http://www.n2yo.com/?s=40277
After testing Express-AM6 will move to 53°E, and after replacement in early May old Express-AM22 will move to 80°E.
