uk bbc channels normally on 28.2 on intelsat 907 27.5w ?
woborny
key change today
woborny
And within a few hours the new ones are available..
BlindFaith
TBS 5925
I just had a S/N drop of 4-5 dB at 11495V. :( Seems to be slowly recovering..
Nagusia
Gibertini 0p150 with single Inverto Black Ultra plugged into Humax FOXSAT HDR | Portable 80 cm dish with IBU plugged into TechniSat SkyStar USB HD DVB-S2 receiver/W7 64 Media Center / ProgDVB setup.
20 km south of San Sebastian N Spain
Sun outage? In my location in N Spain for 27.5ºW it's 15.50 according to to one of those calculator things if I've understood correctly, but where you are the peak was 15.50 yesterday, but only lasted 3 minutes or so. If I'm home in time I'm going to check this out today.
BlindFaith
TBS 5925
Sun outage?
not possible, it was in the evening ;)
maybe bad weather though it wasn't that bad. ATM the carrier has fully recovered :)
Retired Mod
www.timo.me.uk
We've had some heavy localised rain showers in the past few days here in the UK. Maybe one was passing over the uplink?
kota
VU+ Solo2,Humax HDCI2000,Astra2 1.80m Famaval dish/Inverto Black Pro,Astra1&Hotbird 90cm dual lnb dish,Astra3 1.20m dish,Intelsat 907 80cm dish, Hispasat 60cm dish.
Sintra - Portugal
has there been yet another key change today ?? Black screen here
BlindFaith
TBS 5925
no, same as before :)
kota
Sintra - Portugal
MarkW
1.2 Galaxy,IBU single,Technomate 5402M3
Jesi,Italy
kota
Sintra - Portugal
actually no. I've changed my bbc_pmt_starter.sh file with the wrong one. It's all sorted now.
TedWard
Skybox v8,Skybox F3,1.2 metre dish,80 cm dish
Spain
Please help Gurus,im trying to get Intelsat 907,the other arf likes her Dancing and of course the jungle comes on soon,i have finally locked on to the Intelsa 907 transponder 11496 v 44103,the signal quality is 90 and quality 73,please bear with me.
when I search for programmes my box says no programmes found,i assume this is because of the biss keys?.
Now I am using an Skybox F3 which accepts Biss keys and I think it accepts the high signal rate would I be correct in this,i have put the biss keys onto box already but still no programmes any help will be greatfully recievedand very much appreciated keeps her off me back you know lol,cheers guys.
Deso
1.2m Generic dish, Sky+ HD and Technomate TM5402 HD box.
Fuerteventura/UK
It won't work with that box I'm afraid. The easiest and best boxes to use are the Technomates, TM5402 HD or TM F3/5 HD, the latter is slightly cheaper at around £99.
You would need to 'patch' the box first with Phantompatch and then have a read of the thread I have sent you via PM (Conversation) ;)
TedWard
Spain
Ok thanx very much Deso im in Spain and never see any technomates but there is a local seller who might just sell me the box don't know what make but will find out as I posted on another thread,the Tp im locked on is 11496 v44103,and the bbc on ntelsat907 is 11495 v 44100 am I on the right Satellite lol cheers for reply mate...Ted
Yup thats the one - be aware that this illicit BBC source could be locked down securely at any time, or it could stay available for many months. Arqiva know full well that their 27.5W frequency is being widely hacked.
Tururu
Assembled with recycled parts
Recycled as the owner.
@ TedWard
Not finding channels is no problem of keys kiss.
Many decos not stand or see these channels, so in the end there is nothing.
It seems that your deco is one of them, in some models, pid can be put by hand, not others in the network (intenet) is indicated as decos and support it.
Question of reviewing other post.
In many areas of Spain with larger antennas can tune 28'2ºEste position.
Luck.
No encontrar canales no es problema de las llaves kiss.
Muchos decos no soportar o ven este tipo de canales, por eso al final no encuentra nada.
Parece que su deco es uno de ellos, en algunos modelos, los pid se pueden poner a mano, en otros no, en la red (intenet) se indica como y que decos lo soportan.
Cuestion de repasar el resto de post.
En muchas zonas de España con antenas mas grandes se puede sintonizar la posicion 28'2ºEste.
Suerte..
The DreamBox800S-HD is one of the tuners that do not support it, but if they can search.
La DreamBox800S-HD es uno de los sintonizadores que no lo soportan, pero si los puede buscar.
TopGear
GM Spark Triplex - 90cm dish @ 0.8w, 5e, 13e, 19e, 23e, 28.2e - 90cm dish @ 27.5w
Estonia
Yup, even if they close that option, there are new ones. Like IPTV example...
Not practical for many expats where thay have slow broadband or low caps on the download limits
TedWard
Spain
I actually have a mag250 box and subscribed cough cough but didn't like the picture very blurry unless thats because of the provider,you cannot beat the sat picture for sure...
mick stalham
1.4 dish humax box tuned to astra ???? lost all bbc channels
seron southern spain
thanks for reply i have had a look at dish prices and i can get 100cm for only 17€ more than the 80cm so i think i will order one of these to be on safe side. I know they say its not the size of it but what you do with it that counts but i think i will be happier with the bigger one!!!!! ha ha
i was going to order the amiko mini hd box but another member recommended the Technomate 5402 do you think this would be better ?
hi all
i ended up buying a amiko mini box with biss codes installed.
i fitted a 100cm dish and it all works fine.
i have just purchased another amiko box to put upstairs. i have plugged it in and intelsat907 is installed in satalite list but when i search for channels i find none. i think i need to upload software ?? where would i find this ? i have searched on google but not had a lot of luck. any help would be appreciated
thanks mick
