Yes, very. One of many pictorial images depicting the same outcome.ooohh creepy..
We can but hope!..Satellite receiver constructors & their admin are a bunch of cowboys ripping off their customers for maximum profit $$$$$$$$$$$$$$
Let's hope that a UK company takes on the Far East Cowboys.
Well that's why we buy the tbs cards as we are not "normal"It has been said before that all that they are interested in is main stream users that just want to watch tele on 28E.The number of android boxes about is bewildering.
Edit just looked at my Avitar first time for a long time.Not bad looking then was I.Ye Gods I look a bit different now.
well. here we go again got yet ANOTHER technomate, this time a 5302 and STILL the blind scan goes through everything .. totally ignoring my range I set .. I give up, I really do
standard factory software, straight out the box
Rob :mad:
nope still happening even with phantom, and factory reset,
28.2e checked
TP RANGE 107-1099 ( TEST)
STEP SCAN 3MHZ
POLARIAZATION ALL
SCAN OPTION TP+CHANNEL
SEARCH TYPE ALL
RADIO CHANNELS NO
THEN I PRESS RED IT STARTS TO SCAN BUT SCAN THE WHOLE RANGE IGNORING MY SET RANGE.
hmm.. gawd knows.
10700 to 1099 won't work either. Try 10950 to 11200 which is a valid rangetypo 10700 to 1099.
tried it from various ranges.. doesn't work
Am i thinking your trying to scan the LO setting range and not the frequency range of the band ?? .... i can't be right thinking that Rob, can i ??
