What should i buy for feeds ?
rob12770
fac ita
Glasgow
2 X Technomate TM-5302HD, Blade 7000s, triax 95cm STAB HH90, 1 M TM dish TM2300 super motor.
Glasgow
ooohh creepy..:eek:
pontiend
Contibruter
south yorkshire
I use DVBDream.I get problems too.It is a bit like my Alien2 reciever.I sometimes gets problems when on a transponder with no signal.The alien just cycles and gets nowhere.DVBDream shows Not Responding.if you wait a bit it normally recovers.Sometimes it will white out.The TBS card driver goes missing and a reboot is the only way to get it back.Re the positioner.If you have a signal on a transponder when using it it works fine.If no signal it will white out.Or crash.If you want to change the longtitude on the postitioner there must be a signal on the transponder.Sorry about going on a bit this is just my experience.I have tried Prog DVD no good to me. It looks ok if you want to watch tv.I need another can after all that.:)
Satellite receiver constructors & their admin are a bunch of cowboys ripping off their customers for maximum profit $$$$$$$$$$$$$$
Let's hope that a UK company takes on the Far East Cowboys.
We can but hope!..
pontiend
Contibruter
south yorkshire
It has been said before that all that they are interested in is main stream users that just want to watch tele on 28E.The number of android boxes about is bewildering.
Edit just looked at my Avitar first time for a long time.Not bad looking then was I.:)Ye Gods I look a bit different now.:D
Archive-8
Well that's why we buy the tbs cards :p as we are not "normal":D
rob12770
fac ita
Glasgow
Glasgow
well. here we go again got yet ANOTHER technomate, this time a 5302 and STILL the blind scan goes through everything .. totally ignoring my range I set .. I give up, I really do :(
standard factory software, straight out the box
Rob :mad:
Archive-8
Rob :mad:
You must be doing something wrong, 1 dodgy box is a possibility, but not the amout you have gone through.
You must be missing a button push. Both my 5302's are flawless. (Apart from the 45000 symbol rate issue)
rob12770
fac ita
Glasgow
Glasgow
I CANT SEE WHAT THOUGH.. I REALLY CANT oops caps lock
rob12770
fac ita
Glasgow
Glasgow
I picked up an old blade 7000s and that does it fine..
gonna try it with phantom p
rob12770
fac ita
Glasgow
Glasgow
nope .. STILL scanning everything.. even with phantom...nightmare..
rob12770
fac ita
Glasgow
Glasgow
nope still happening even with phantom, and factory reset,
28.2e checked
TP RANGE 10700-10990 ( TEST) ( edited post / typo)
STEP SCAN 3MHZ
POLARIAZATION ALL
SCAN OPTION TP+CHANNEL
SEARCH TYPE ALL
RADIO CHANNELS NO
THEN I PRESS RED IT STARTS TO SCAN BUT SCAN THE WHOLE RANGE IGNORING MY SET RANGE.
hmm.. gawd knows.
Archive-8
28.2e checked
TP RANGE 107-1099 ( TEST)
STEP SCAN 3MHZ
POLARIAZATION ALL
SEARCH TYPE ALL
RADIO CHANNELS NO
hmm.. gawd knows.
Do you mean you have set it to 107 to 1099?
rob12770
fac ita
Glasgow
Glasgow
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
typo 10700 to 1099.
tried it from various ranges.. doesn't work
10700 to 1099 won't work either. Try 10950 to 11200 which is a valid range
Both ranges you type must be 5 numbers as Andy says else it won't work
eg 10750-11750 0r 11750-12500 and so on, infact any range between 10700-12750 for a universal LNB.
Am i thinking your trying to scan the LO setting range and not the frequency range of the band ?? .... i can't be right thinking that Rob, can i ?? :eek:
I think iv'e been out in the sun too much Chris, either that or i'm loosing it :rolleyes:
