Same with me John
A difficult catch for me recently. Nothing to show at present.
Hi John, is it the Max Hold option in the Advanced menu?Cheers Llew, OT... the other day i noticed some screen info on your Promax grab that i don't see on mine, when i get a minute i'll try and remember what it was and give you a buzz.
----------------------------------------------------------------------------------------------------------------------------------------------------------------------OH wait a mo, here's the one I did a little while ago,, which shows the effect more clearly -
-----------------------------------------------------------------------------------------------------------------------------------------------------------------------Hi John
Yes, you're way out of date. Looks like you have the original software version, before any updates have been downloaded. The PLP option etc. came several updates back.
I'm on v.20.1 at present, there's a v.20.2 available, but it doesn't have much added that I need for now. Irritatingly, in v.20.2, Signal Parameters (F2 button) defaults to Generic, so I have to keep changing to DVB-S or DVB-S2 for it to start searching a signal's DVB parameters.
Can't you force an automatic update in NetUpdate?
My equipment software version -
Ohhh no, I can see another software screw up here..remember what happened to your Televes!-----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Thanks for that Llew, gives me something to work on now.
